HD TV Ready Plasma (budget?)
Discussion in 'Plasma TVs Forum' started by gunneredw, Apr 21, 2005.
  1. gunneredw
    gunneredw
    Apr 21, 2005
    32
    Im looking to buy a 42" high definition ready plasma Tv. As id like to watch hi def sky when it eventually comes out.
    Ive seen the panasonic pv500 which looks good but i dont really want to spend 2500.
    What other high def ready models could i get for a cheaper price?
    Any help grateful
  2. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,242
    2
    4
    137
    Garstang, Lancs
    +1,625
    If you want hi-def then the PV500 should be the only choice for around £2300...
  3. gunneredw
    gunneredw
    Apr 21, 2005
    32
    if there are no hdtv ready plasma screens in the 1000-2000 range. As the pv500 has just come out and i cant even use hdtv till it is launched, wouldnt it be better to buy a 42" standard plasma for say just over a 1000 and then in a years time buy the pv500 for less? say it would have gone down to 1500? then you would get 2 plasma televisions for the same money
  4. Desticado
    Desticado
    Oct 16, 2000
    1,477
    41
    Canterbury, Kent, UK
    +6
    it all depends on if your criteria to buy is simply the presence of HD usability or not.
    I think for a lot of the prospective PV500 buyers (of which im one) it will also depend on SD Picture Quality just as much.
    For me, if the PV500 has a significantly better picture than the PE50 for SD then i'll buy one, if it doesnt then I'll be happy with a PE50 and buy a HD set in 2-3 years time.
  5. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    IMHO..yes
  6. DOCTOR_d
    DOCTOR_d
    Mar 12, 2005
    194
    Yup, from me !
    That's what I was thinking....
