hd .ts file help
Discussion in 'General TV Discussions Forum' started by p.e.no1, May 5, 2005.
  1. p.e.no1
    p.e.no1
    Apr 11, 2005
    140
    +3
    sorry if this is in the wrong forum.
    i have d/l a film that has come in .ts files.although i can play the files individually i would like to join them together to watch as a whole film.
    is there a way of doing this?
  2. tomos
    tomos
    Oct 3, 2004
    149
    yep, think its called hdtv2mpeg
  3. jkirkebo
    jkirkebo
  4. probedb
    probedb
    Aug 20, 2003
    2,653
    Sheffield
    +180
    hdtv2mpeg seems to be fine so long as you don't convert and use .ts as the output format as well. I've not had any problems with that. However, when it converts to MPEG2 I've had severe blocking and other issues.
  5. Ronan
    Ronan
    Dec 16, 2002
    48
    Dublin
    +6
    Copy the files into a directory and from a dos prompt type:
    copy /B *.ts somefile.ts
