HD through optical
Discussion in 'Satellite TV, Sky TV & FreeSat' started by scouse258, Aug 4, 2006.
  1. scouse258
    scouse258
    May 22, 2005
    413
    Newcastle
    +5
    Ok - this is the third time its happened so i dont believe it can be my other equipment - sometimes the sound through the optical cable stops
    i unplug it time and time again but i cant get it back on for quite while. when i put the cable into the dvd player then it plays the sound from this source.
    how possible is it that the optical connection on the sky hd box is knackered - is this a common fault?
  2. CG121
    CG121
    Feb 16, 2006
    368
    +10
    Considering the build quality (or lack of it) of both the HD box and the software, I would say that it's very likely the HD box is the cause of your sound issue...
    Although more likely to be a specific fault with your output, we all know that $ky have always had AC3 issues....
    As they have no interest in researching the fault (through no competition) we're unlikely to see a resolution for a while (if ever)
    I've noticed a few problems with DD5.1 sound, mainly on scenes of intense movement with high contrast, which would appear to indicate a peak in resources within the en/de coding stage that may affect the audio latency...
    However, without the ability to monitor the program stream from playout through to the box output (which $ky should've done) it's impossible to say why it happens..
    TBH, it's not prevalent enough for me to consider it a major flaw, but it's annoying none the less.
    It doesn't cause minutes of silence though and certainly doesn't require the cable be removed...
    I know it does get considerably worse on different amps though...
    Anyone beginning to see a simularity between this and the recent HDMI compatability issue...
    If $ky continue to produce sub standard products through being unable to fully test them due to last minute release dates, we'll all soon need to buy $ky amps and $ky TV's...
    Although that may not guarantee fault free viewing considering they can't make the $ky PVR software and $ky +/HD box work together...
    Micro$oft would've given their right arm to restrict their software to proprietory hardware, but not having that option resulted in a more stable platform through continual development. Technically more challenging which later proved to be the secret of their financial success......OEM..
    & yes, as much as I hate to admit it, NT/2K/XP have been significantly more stable than anything from $ky which is indeed a great feat considering their complexity over the outdated more simplistic PVR from $ky.....
    So fingers crossed it's just (another) faulty box and not the unknown issue between $ky and your AC3 amp....
  3. suffolktoon
    suffolktoon
    Mar 1, 2004
    421
    +24
    This has happened on mine as well. However, I tend to record and play later so it hasn't been a real problem, but it is annoying.
  4. Nicky1964
    Nicky1964
    I have noticed a short sound drop when I play back recordings
    hd or sd and its BOTH the hdmi and optical
    it may just be the sky box locking in but can be destructing sometimes
