HD Sky, HDCP, etc - I am confused
Discussion in 'Sky Digital TV Forum' started by Gillykid, Jan 11, 2005.
  1. Gillykid
    Gillykid
    Mar 4, 2004
    212
    Warwickshire
    Ok, having purchased a HD ready projector last year, I like others are a little upset with Sky's decision to force the use of HDCP, possible rendering my unit unusable.
    I am confused about just how the Sky HD service will now work. At present, information is sent to a Sky digi-box, which descrambles according to your card, then transmits (if applicable) to your screen.
    So how is the new system going to work. If the service is designed to send encrypted information to the screen for it do descramble, at what point does the service decide what you can and can't watch? I assume this cannot be at the point of the television, and must be at the digi-box. If this is the case then why encrypt the final signal at all?
    Or am I just going mad???
    :rolleyes:
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    its to stop you making copies of the broadcast.........HDCP is the new copy protection system so once you have your box and card to allow you watch the broadcast signal of channels you pay for they then add HDCP to stop you recording it!!!!
  3. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    It's the viewing card that tells the box what you can or cannot watch. However, it would be too easy to circumvent the card, if the data was not encrypted. The use of HDCP will give Sky a new level of power - the ability to prevent recording of the HDTV material. This is also a feature of the existing box, but is easy got around if you know how, but isn't so easy to do with HDCP.
  4. ScubaPro
    ScubaPro
    Hornydragon is your name Kevin by any chance ?
