HD screen res problems when using x800xt
Discussion in 'General TV Discussions Forum' started by avinitski, Jul 24, 2005.
  1. avinitski
    avinitski
    Apr 22, 2005
    3,313
    +215
    im outputting a HD signal from my pc using an x800XT, my DLP TV supports 720p/1080i
    using ati software when i select 720p/1080i the screen ever so slightly doesnt fit on the TV, i have to manually decrease the resolution to 1184x672 for 720p
    is this normal? any way to have the full correct screen resolution?
    also now if i output a HD movie (1280x720 for 720p mode) wudnt this be degrading the quality slightly?
  2. Razor
    Razor
    Dec 15, 2004
    37,566
    2
    +12,432
    I have a x800xtpe and have no such problem. Have you got a samsung 50' by any chance?
    Overscan is common on these DLP sets.
  3. indie24
    indie24
    Oct 3, 2004
    989
    london
    +262
    if you have the sp50 you can get 0 overscan if you select pc as the output name and then press the resize button.
    hi razor :hiya:
  4. Razor
    Razor
    Dec 15, 2004
    37,566
    2
    +12,432
    Indies :hiya: totally right. :smashin:
  5. avinitski
    avinitski
    Apr 22, 2005
    3,313
    +215
    i have the RE-44SZ21RD
    not sure what overscan is.....is it bad? how do i know if my TV is overscan?
  6. Razor
    Razor
    Dec 15, 2004
    37,566
    2
    +12,432
    Is that an LG?
  7. avinitski
    avinitski
    Apr 22, 2005
    3,313
    +215
    it is indeed
  8. Razor
    Razor
    Dec 15, 2004
    37,566
    2
    +12,432
    :oops:
    How are you connecting the set up? I didnt think the LG had a DVI connection? :confused:
  9. avinitski
    avinitski
    Apr 22, 2005
    3,313
    +215
    it has analog component, (YPbPr)
    so does this tv produce overscan? what ever that is lol
    anyone know why i have to slightly decrease resolution when running in 720p/1080i?
    cheers
