Hd ? Screen Help
S
sivy28
HI I know this is a common issue and I have spent hour going through lots of posts on this forum but to no avail. Id be most grateful for any advice to help in my decision befor i part with the hard earned..
I have the following equipment and need suitable display solution,
sanzio netdvd
yam amp dsp ax750 se
InFocus ScreenPlay 4805
building htpc
pioneer dv 575a
I am at the mo a very confused as to which screen to go for for the best use lcd / plasma? hd / sd ?
I like others will be mainly using it as a tv through freeview and dvd so very concerned that it will look good on sd source sports etc, also will want to utilize the snazio and some content from htpc, so it would seem i should go for a more expensive hd ready screen ?, but is it really worth it ? as from this forum alot of hd screens seem to have bad pictures from sky freeview etc and some people have seen hd material sourced to a hd screen and sd screen (panny pe50) side by side and said that it would be hard to tell the differnce. I would go for a sd screen like the pe50 as it will take hd over componant but then im not sure how i would best connect the htpc etc?
or is there a similar sd screen with able to take hd but with better connections? I dont really want to have to fork out over 2000 for a screen if I can help it especially if there is a solution which will handle some hd material without losing too much picture quality compared to the latest hd panels.
screens ive been looking at are
pannyTH42PE50B
tosh 37wlt58
jvc PD42DX6?
phillips37PF5520
phillips42PF7520
need above 32
I know 42 pv500 and the new pioneer seem just what the doc ordered but a little out of buget im afraid
any suggestions please apart from wait another 6 months :lease:
