HD sat feed
Discussion in 'Televisions' started by tigertimtim, Aug 20, 2005.
  1. tigertimtim
    tigertimtim
    Mar 31, 2005
    625
    +263
    According to KingofSat website theres a high def from C More Hd on Thor.
    Thor 2 (0.8W) - 11261.00 H - DVB - 24500 7/8 - NID: 70 - TID: 33 - Txp: 4 - Beam: Nordic -
    english movies as well by looks of things, shame my sat reciever wont take HD feeds.
  2. GalileoFigaro
    GalileoFigaro
    Aug 13, 2005
    As we speak I am fishing a SkyStar 2 card out of my old PC to see what we can see - with the new HD software. (All I'll need then is a HD TV!) :D
    Thanks for the info tigertimtim!
  3. sprattgraham
    sprattgraham
    Dec 10, 2004
    928
    28
    Hertfordshire UK
    +28
    Thats Working.
    It's Canal+ HD Channel Thats Going To Start In September I Think
  4. GalileoFigaro
    GalileoFigaro
    Aug 13, 2005
    Yehey! I got my SkyStar 2 card going in HD! I am impressed - roll on September 1st - and I might just have a TV by then too! :D
    My Athlon 2600+ (running actually at 2GHz) keeps up with the feed about 90% of the time before occasionally going pixelated etc. At least I have a valid excuse now for upgrading my processor!
  5. GalileoFigaro
    GalileoFigaro
    Aug 13, 2005
    I know this must be noobie question no 867, but since this HD feed has a resolution of 1920 x 1080, should I set my PC display resolution to the same, put the picture on full screen and link to the TV with my VGA out . . . or what?
  6. pjskel
    pjskel
    Oct 12, 2004
    2,676
    83
    UK
    +124
    Yes, I would believe so, since the projector or TV is acting as a mirrored display.
  7. Stephen Neal
    Stephen Neal
    Mar 29, 2003
    6,080
    +681
    What is the resolution of your TV? If your TV isn't 1920x1080 resolution, then you might be better off setting your PC to the native resolution of your display, and getting the PC to scale rather than the display?
  8. GalileoFigaro
    GalileoFigaro
    Aug 13, 2005
    Thanks for the advice folks.
    To be honest it's all a bit theoretical to me until I actually get the TV, but I'm only looking at the latest mid-priced fayre and those appear to have a resolution of around 1280 or 1360 or 1366, so I'm sure I'll be doing some experimenting!
    In the meantime I better order a very long VGA cable and maybe an adapter or two depending on which TV I get.
  9. RecordablDVDfan
    RecordablDVDfan
    Aug 13, 2003
    2,869
    68
    +47
    This channel will be encrypted anyway from Sept 1st and you can't subscribe outside Scandinavia... I presume NID and TID means Video PID and Audio PID ?
  10. RecordablDVDfan
    RecordablDVDfan
    Aug 13, 2003
    2,869
    68
    +47
    Only TWICE the picture quality he says...oh dear
