HD Resolution Output
davybaker
I'd set the HD output of the box to 1080i. Most if not all of SKY's HD content will be (or have been) filmed in that. Even if your screen is not a full 1920 by 1080 pixel layout it'll still look pretty good!
colin45
Thanks for the quick answer I have a Sony X and have been using the Automatic setting, will 1080i be the best setting be for SD viewing as well
Tony Hoyle
With 1080i you don't get widescreen switching, so it really depends on how much 4:3 material you watch. Personally I think Automatic also gives a much better SD picture but it depends on the TV I guess... try both.
colin45
I am a bit new to all this but on SD when I tried the Automatic setting (the resolution was set to I think 576p) the program planner was not very clear I tried it on 1080i and the planner was much clearer but I do not know if this is a good guide to use. It seems to me that depending on what program I watch the PQ. is different so I am having problems deciding which is best
Tony Hoyle
The planner is scaled to the resolution so isn't really a good way of comparing - you need to look at SD programming and see what you prefer.
For me it's no contest since some of the channels that I watch (SciFi, Paramount Comedy) are not widescreen so 1080i simply won't work.
B
btocher
I'm in the same position. I much prefer viewing widescreen, but I do watch some stuff that's 4:3 (CNN and some old TV series, for example). The automatic setting works just fine for me.
