HD Recorders that auto name recordings
Discussion in 'Blu-ray & DVD Players & Recorders' started by tabatha, Jul 16, 2004.
  1. tabatha
    tabatha
    Jun 9, 2004
    180
    16
    West Midlands, UK
    I was pleasantly surprised when I first used a Panasonic DMRE100 as it automatically names off-air recordings from terrestrial TV with the name of the programme from the details given by Teletext together with the channel and time.
    Do the newer Panasonics do this as well and do any other recorders by other manufacturers do this?
  2. Kevo
    Kevo
    Aug 23, 2001
    5,398
    Manchester
    +149
    I would imagine they do, but it's annoying that it doesn't record such info from DTV recordings. You would think it possibe and even easier with digital recordings.
  3. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    844
    19
    leeds UK
    +15
    THe earlier hs2, and presumably the dvd only panasonic recorders also do this, but it is a bit hit and miss as to whether it is correct or makes sense. Personally I always name the recording in the timer set up to get the name I want
