  2. Notice: AVForums will be offline at 10pm for no longer than 30 minutes for scheduled maintenance. Apologies for any inconvenience this causes.
HD Ready LCDs Any Benefits on watching NON HD output
Discussion in 'LCD & LED LCD TVs' started by malibu, Aug 7, 2005.
  1. malibu
    malibu
    Jul 23, 2005
    9
    Are there any benefits of watching Normal TV with a HD ready LCD compared to a NON HD ready LCD or CRT set ?
    are they better then say watching a movie Trailer on a older NEC PC type monitor,
    MALIBU :)
  2. pjskel
    pjskel
    Oct 12, 2004
    2,676
    83
    UK
    +124
    The only potential benefit would be if you get yourself the likes of a Samsung 850 or 950 DVD player, which can output at 720p and 1080i. It'll turn your DVDs into something a little bit better than they already look on the CRT.
    Otherwise, no major difference, but as HD is coming in one form or another (Sky/pre-recorded HD-DVD or BR discs) then you'd be better off with a HD Ready TV than one that wasn't.
    Especially, if it's a one off purchase to last the next 5 years at least.
