HD PVR to PC
Discussion in 'Digital TV & Video Players & Recorders' started by jimbowley, Nov 3, 2004.
Tags:
  1. jimbowley
    jimbowley
    Oct 24, 2004
    158
    16
    Does the Pace twin or other HD recorder let you output the files to PC. (And then can you write them as a DVD for playback on any DVD player)?
    thanks, jim
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,395
    Rainham Essex
    +2,452
    All PVR's can be output to a PC if you have a capture card in the PC. Most capture cards only work with composite or S-Video so the quaity wont be great, but it does work.
    Mark.
  3. jimbowley
    jimbowley
    Oct 24, 2004
    158
    16
    I realise they output a video signal :zonked: but can you output the data file?
  4. MarkE19
    MarkE19
    Aug 10, 2002
    17,395
    Rainham Essex
    +2,452
    Not legally!
    If you rip the digital data and burn to a DVD or even just store it on another HDD is is technically software theft. It is easily possible, but the HDD has to be removed from the PVR. If you want more details you will need to do an internet search as we are not allowed to disscuss this on the forum.
    Mark.
  5. FinnMan
    FinnMan
    You can rip files from Twin's disk using TwinRIP:
    http://groups.yahoo.com/group/TwinRIP/
    There are also some PVRs with USB2-port. You can connect those machines directly to PC. I'm not sure what brands are available in the UK.
    E.g. Topfield has one model:
    http://www.topfield-australia.com.au/product.asp?SKU=TF5000PVRT
    And it is not illegal as long as you don't sell or give your burnt DVD's to others.
    Regards,
    FinnMan
  6. Oldjim
    Oldjim
    Oct 29, 2004
    77
    I don't understand that statement. Virtually all the HDD DVD recorders include DVD writers to permit you to do exactly that. Why is that legal and doing it using an external writer not.
  7. jimbowley
    jimbowley
    Oct 24, 2004
    158
    16
    And you can connect the twin to a PC via what connection? I don't want to remove the HD and install it in a PC !
  8. FinnMan
    FinnMan
    Thats the only option with Twin, you would need to remove+install the HD.
    What you need is a STB with USB/USB2 (Topfield or similar) from which you can transfer files to PC (may be slow).
    Or you need an internal or external tuner add-on to PC, with which you could record directly to PC's HD.
    (e.g. http://www.hauppauge.co.uk/pages/products/data_dec2000-t.html )
    Above mentioned are freeview digital receivers.
    There are also many HD/DVD-writer combinations available for analog TV-networks (JVC, Panasonic, LG, Philips etc.) with which you can do what you want without a PC. I don't again know about UK availabilty of those gadgets.
    Regards,
    FinnMan
