HD Players -v- SD Players Power Requirements
Discussion in 'Blu-ray & DVD Players & Recorders' started by fortean, May 1, 2007.
  1. fortean
    fortean
    Nov 28, 2004
    825
    Chorley
    +71
    One of the things many people consider these days when purchasing equipment is the power consumption.
    From the respective manufacturer sites I found the following...
    Toshiba SD-370E-DVD Player 10W
    Toshiba HD-E1 41W
    Toshiba HD-XE1 50W
    Panasonic DVD-S53EB 10W
    Panasonic DMP-BD10 42W
    ...as you can see, HD players at present require a four fold increase in power.
    If this is because they are more similar to PC's then is this something we will have to live with or are they likely to be able to bring down the power requirements to be more in line with SD players?
    Just using a HD player for 10 hours per week is going to consume an extra 15+ Kw per year.
  2. Bald Monkey
    Bald Monkey
    Aug 11, 2006
    7,123
    +1,084
    :eek: OMG !!! We're all dooomed!! :D
    Just unplug your mobile charger when you're not using it, it'll balance that out ;) :D
  3. fortean
    fortean
    Nov 28, 2004
    825
    Chorley
    +71
    If I had a mobile phone charger plugged in I would do that :) but they only use between 25 and 35 watts when in use; much less if not charging something.
    From an individuals point of view it may not seem significant but if the government want to ban standby on TV's etc. then since my TV uses 0.3W on standby, if I leave it on standby for 18 hours per day that's still less than 2Kw per year.
    Anyway, what you've commented on is just a fact. What about the question I asked?
  4. CarlB
    CarlB
    Jan 8, 2001
    1,358
    Cambridgeshire
    +282
    It's small change compared to the power your 50" plasma sucks out of the wall...
  5. fortean
    fortean
    Nov 28, 2004
    825
    Chorley
    +71
    I agree with you on that. But the TV gives me a bigger and better picture. A HD player gives me a better picture so I am willing to pay more for that too.
    But is the extra power needed for the processing to decode the picture stored on the disc. If they encoded the content in a similar way to SD DVD would the power requirement be closer to a SD player? It would take more space up on the disc at the expense of other features. Are HD discs capable of storing the same amount of content time as SD discs are but at HD resolution? If it's just for the high level of encryption that the power requirement goes up then there's a good argument against such encryption.
    What I'm trying to understand is why is there such a leap in power requirement for HD over SD? It can't all be to do with the final output signal.
  6. Avi
    Avi
    Dec 30, 2004
    13,963
    +2,064
    I suspect it's due to increased video and audio processing requirements plus some designs also use "PC type" technology that will probably disappear in a few generations.
    How does this compare to using a PS3 or Xbox as a player ?
    AVI
  7. Grumble
    Grumble
    Mar 16, 2005
    223
    20
    St. Andrews, Fife
    +85
    It's probably down to the cooling fan :rotfl:
  8. Avi
    Avi
    Dec 30, 2004
    13,963
    +2,064
    Bottom line is the player is processing much more data. SD DVD is using around 345k-414k of image data plus compressed audio. HD DVD and BD is processing 2073k of image data alone. Then compound that by processing increased audio data, audio stream mixing (HD DVD) and interactive features etc. i.e. more like a computer
    Just like a computer the more processing the greater the power draw.
    AVI
  9. richard plumb
    richard plumb
    Jan 27, 2002
    14,524
    Windsor
    +1,054
    it'll come down over time as they move to SoC and general computing power increases (and therefore you don't need the bleeding edge stuff which is usually power inefficient)
    Not sure if it'd come down to the levels of modern DVD players, as the general specs are higher, but then things move on so maybe.
    It'd be interesting to see the power consumption of launch DVD players
  10. fortean
    fortean
    Nov 28, 2004
    825
    Chorley
    +71
    Panasonic DVD A-350 is 22W - It does have 6 channel output though.
  11. Avi
    Avi
    Dec 30, 2004
    13,963
    +2,064
    The current Denon 3930 SD DVD is rated at 70w and the Denon 2930 SD DVD at 45w. :)
    AVI
  12. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    These numbers are all small in the grand scheme of things. The consumption is down to the processing and facilities needed. Some DVD players can consume much more than these devices.
  13. TrevorS
    TrevorS
    Dec 2, 2005
    974
    43
    +175
    Just hunted for and found the power spec on the Sony DVP-S7000 (Original DVD player) -- 28 Watts!
  14. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    Many good 2000 era DVD players are around 25 - 35w
  15. james.miller
    james.miller
    Dec 16, 2002
    2,616
    +143
    hd players have to work with a 5 fold increase in resolution and far higher audio bitrates. Therefore its not unfair to assume they will use 5-6 times more power. that fact that they use less than that is a bonus really.
  16. ash
    ash
    Jun 9, 2005
    11,296
    +396
    I doubt many people have 10 hours worth of HD films to watch a week :D
    And most people still have their super-duper SD DVD players.
  17. peterweg
    peterweg
    Feb 8, 2002
    1,351
    48
    +86
    http://www.llamma.com/xbox360/news/inside_the_xbox_360_elite_part_3.htm
    http://www.hardcoreware.net/reviews/review-356-3.htm
    Basically they guess consumption will be a bit more than peak game playback, with the difference being the add-on drive spinning.
    http://www.digitaldisplacement.com/?p=1907
  18. Sonic67
    Sonic67
    Sep 14, 2006
    46,418
    12
    167
    Home
    +25,468
    Going green:
    http://environment.guardian.co.uk/energy/story/0,,2055225,00.html
    To leave my mobile phone charger on standby, plugged in but not charging, uses 0.009 kWh a day. So in effect, I could leave it on for over a year - 380 days - for it to have consumed the same power as running a bath, which for a single 90 litre soaking uses 3.5kWh.
