HD player to DVD question
Discussion in 'Blu-ray & DVD Players & Recorders' started by steveenduro, Mar 8, 2006.
  1. steveenduro
    steveenduro
    Hi All.
    I'm relatively new to video processing/editing and have a question regarding compatibility.
    I have copied some old 8mm camcorder footage to the HD on my Toshiba RDSX32. I wish to do some very basic editing and copy it to DVD. I have a pc with DVD-RAM capability. I am thinking of copying my footage to DVD-RAM on the Toshiba, saving it to hard disk on my PC, then editing and burning onto DVD-R or DVD-RAM. Is this possible? I'm unsure of the formats involved.
    Is this the best way to accomplish this, or should I struggle along and edit on the Toshiba and then burn directly to disk on this machine rather than pc?
    Any help appreciated.
  2. steveenduro
    steveenduro
    Hi All.
    I'm still struggling with this one.
    I've now transferred some 8mm video onto my Toshiba rdsx32 recorder hard disk.
    It is DVD-VR format. I would like to be able to transfer it to my pc for editing, but I am stuggling to do this. Windows Movie Maker does not recognise it.
    Any thoughts?
    Cheers.
  3. felix2
    felix2
    Jun 21, 2005
    457
    28
    Felixstowe
    +40
    Hi!
    Yes, you can do basic editing (cutting and splicing) on the Tosh hard disk (although you might get a slight pause at splice points), and burn it onto DVD-R (or -RW or -RAM).
    But you're right, you'll be able to do more with your editing by transferring it onto the PC (via either a DVD-RAM or DVD-RW). The video will be MPEG2 format. To get Windows Movie Maker to recognise that they are MPEG files, you may have to rename the .VOB files (in the VIDEO_TS folder) as .MPG, although I think some people have had problems getting the sound to work. Also, WMM will not save the video back to MPEG nor burn a DVD.
    But there's all sorts of other software that might be able to help (and usually import the MPEG video straight from the DVD). A basic DVD Authoring programme (e.g. NeroVision, sometimes free with a DVD writer) should let you do editing slightly better than the Tosh. I use Ulead DVD Movie Factory 4, which is good for DVD editing and authoring. "Proper" video editing programmes will give you more flexibility, and most should do a decent job with MPEG. And there's specific MPEG editing programmes (e.g. Womble, Video ReDo, TMPGenc MPEG editor). A lot of programmes are available for 30-day free trial downloads. And for best quality, since MPEG is a "lossy" compression, you want something that re-encodes the MPEG as little as possible.
    Have a good search on the "Camcorders & Video Editing Forum" on here for MPEG editing - that should help you on your way, but do ask any more questions as and when!
    [PS. "HD" tends to stand for "High Definition" in the video world now, easier to use "HDD" for hard disk drive!]
  4. ROYOLD
    ROYOLD
    Jul 5, 2005
    3,898
    103
    Royton, Oldham. Lancs.
    +296
    You seem to be going a long way round for this.
    You can record to DVD-RAM on your Toshiba and then edit the RAM disc on the Toshiba.
    It's possible to do this on the Panasonics so I do not see why it cannot be done on the Toshiba. No PC involved.
  5. Stevie DVD
    Stevie DVD
    Dec 7, 2005
    11
    If you do decide to go ahead and use your PC for the editing then Computeractive recommends three disc-burning applications: Roxio's Easy Media Creator 8 (£60); Nero (£60) or as a free download Deep Burner. Hope this helps.
