HD plasma 32" - 38" - where ?
Discussion in 'Televisions' started by bl0ckev, Sep 6, 2005.
  1. bl0ckev
    bl0ckev
    Sep 25, 2004
    2,507
    +176
    Well im looking for around the size stated of 32" - 38" HDTV plasma as i think 42" id bit big for where im going. Hopefully getting a smaller size should save me a bit in money! But im finding it hard to find a plasma high definition TV of these smaller sizes ?
    Anyone help?
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    ......... because cramming all those pixels into a smaller space is much harder and more expensive to do, because the pixels have to be smaller.
  3. loz
    loz
    Jun 4, 2001
    13,058
    +1,796
  4. sprattgraham
    sprattgraham
    Dec 10, 2004
    928
    28
    Hertfordshire UK
    +28
    Sagem do a 32" LCD Panel thats HD Ready for £1099.99
    Sagem HDL32T Spec
    • True HD ready with HDMI and Component input
    • Freeview DVB tuner with 300 presets and 7 Day EPG
    • WXGA LCD panel 1366 x 768, 800:1 contrast ratio, 500cd/m2 brightness
    • 2 x Scart sockets
    • PIP (Picture in Picture) & PAP (Picture and Picture)
    • Analogue tuner with 200 presets and teletext
    • 7 in 1 card reader for digital camera media cards)
    • 10 integrated speakers including 2 subwoofers)
    • Detachable Glass table stand)
    • High quality black cabinet with piano black edging)
  5. bl0ckev
    bl0ckev
    Sep 25, 2004
    2,507
    +176
    It is nice but looks like the bigger it is the cheaper it is :rolleyes:
    Charming
  6. bl0ckev
    bl0ckev
    Sep 25, 2004
    2,507
    +176
  7. bl0ckev
    bl0ckev
    Sep 25, 2004
    2,507
    +176
    A question about what HD is............ is this like a TV which has a port for some new cable which will plug into TV and then into for example PS3 which will have this special port aswell? Or is it something within the TV itself which changes anything on screen to HD?
    As ive heard xbox 360 as PS3 will be better on HDTV ...... im lost
  8. sprattgraham
    sprattgraham
    Dec 10, 2004
    928
    28
    Hertfordshire UK
    +28
  9. sprattgraham
    sprattgraham
    Dec 10, 2004
    928
    28
    Hertfordshire UK
    +28
    The H & B 3200B £889.91 - Should be OK but I think the Sagem 32" LCD £1099.99 - has a better spec.
    The Relisys RP42AB20 £1086.88 - as far as I can see is not HD Ready it only has a max resolution of 852 x 480 and you need a minimal resolution of 1280 x 720 and it doesn’t have HDCP so it want work with Sky’s HD
  10. bl0ckev
    bl0ckev
    Sep 25, 2004
    2,507
    +176
    so it sounds like a bit of both then to be honest. Better kind of resolution and also some kind of part to allow HD signals to be sent to what ever devices!
  11. bl0ckev
    bl0ckev
    Sep 25, 2004
    2,507
    +176
    Should i look at LCD or Plasma's ?
  12. bl0ckev
    bl0ckev
    Sep 25, 2004
    2,507
    +176
  13. sprattgraham
    sprattgraham
    Dec 10, 2004
    928
    28
    Hertfordshire UK
    +28
    Think you have more chance of getting a HD Ready LCD than a HD Ready Plasma. It depends If you want to watch HD.
    Until 2006 you can only get HD from a satellite Channel called Euro1080 or download it off the internet. When Sky start there will be HD Football and Movies and other stuff. At some point you will be able to get HD-DVD.
    You can get a Sagem 45" DLP Rear Projection that is HD Ready - £1599.00
    http://www.comet.co.uk/comet/html/cache/650_237515.html
  14. bl0ckev
    bl0ckev
    Sep 25, 2004
    2,507
    +176
    projection wont be great for thegaming side! I want a HD ready mainly for PS3 and TV (sports, movies) like you say! So projection is probly not the one i need
  15. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    If you have a limited budget, think about DLP - either a projector, or a rear-projection TV. You can get HD-ready DLP's at quite a low price.
  16. bl0ckev
    bl0ckev
    Sep 25, 2004
    2,507
    +176
    projection will be crap for games tho right ?
