HD+ /Pio 868AVi (59AVi)/ Panny PW6D
Discussion in 'Projectors, Screens & Video Processors' started by Ari-Martti, Feb 16, 2005.
  1. Ari-Martti
    Ari-Martti
    Jul 29, 2004
    Anybody using HD+ with Pio 59AVi (868AVi) and Panny PW6(the basic consumer model)?
    With what kind of settings/combinations you have got the best PQ (especially with PAL 50 material)?
    I gave up waiting for that 50Hz DVI blade for PW6, and chose the HD+ route with VGA connection to PW6.
    I am asking especially about the resolutions you have used between HD+ and PW6, 868AVi film modes (on/off/auto) etc, i.e. how to get the most out of HD+ with PW6 and 868.
    Btr,
    A-M
  2. Chris5
    Chris5
    Mar 21, 2004
    1,305
    63
    Herts., uk
    +184
    I use an 868 with HD+ (with dlp tv though) you have to use 576p connection to the HD+ as it does not currently support 576i, obviously you dont want to use higher resolutions eg 720p as you will be defeating the point about buying a scaler
