HD pic from Xbox but how do I get sound on LCD
Discussion in 'Xbox Forums' started by Malone, Aug 25, 2005.
  1. Malone
    Malone
    Mar 12, 2001
    1,857
    Ilkeston,Derby
    +71
    Humm...... :confused: I have a 26PF5520D which has DVI input but no component. I have the MS Hi Def pack Xbox end and have a DVI to VGA adapter and a VGA to component lead. Everything is fine, luvvverley pic on LCD BUT no sound. The only sound input is next to DVI connection which says DVI audio. This looks like a small 3.5 mm headphone jack :confused: .
    I cant see any way to get sound as when AV mode selected for HD you cant change sound input. Am I stuffed. Other than taking phono's to an amp.(Which is all packed away pending a possible house move)
    Matt
  2. Colgate7110
    Colgate7110
    Sep 12, 2004
    768
    28
    Glasgow
    +75
    What about this? It's £2.99 from Maplin here and gives you a 3.5mm connector to go into your DVI Audio jack while the 2 RCA connectors can be connected to the MS Advanced AV breakout box. There's also a "THX" cable which is £19.99 too but who knows whether it's worth it or not but £3 might be worth a try! :)
    [​IMG]
  3. Malone
    Malone
    Mar 12, 2001
    1,857
    Ilkeston,Derby
    +71
    Thanks Colgate, for £3 its worth a go. I assumed standard 3.5 would be analogue so would not work with a DVI Audio in. As I said it looks like a 3.5 jack but like you say I shall have to give it a try. :smashin:
    Matt
  4. Colgate7110
    Colgate7110
    Sep 12, 2004
    768
    28
    Glasgow
    +75
    No problem Matt - hopefully it will work out okay for you. From looking at the specs for your LCD it's a bit vague but it doesn't give the impression there is any sort of digital audio processing options built in (other than the Dolby Virtual Surround processing of an analogue signal). I've even just downloaded the manual for a quick look and it's useless! It looks like the lead should be a success, ot at least I hope so for your sake - I can't imagine gaming without sound! :)
  5. CAS FAN
    CAS FAN
    Nov 24, 2003
    34,988
    167
    The Wheldon Road end!
    +8,132
    The other option is just to connect some Powered PC Speakers to the L/R analogue audio out sockets on the HD pack. Not ideal but at least it would give sound during this makeshift senario.
  6. Malone
    Malone
    Mar 12, 2001
    1,857
    Ilkeston,Derby
    +71
    I must admit I had considered running it through my (admittedley crap) laptop speakers definitely last resort :D
  7. geewhizz
    geewhizz
    Jan 2, 2005
    2,407
    +84
    I use the same cable for my Ipod dock to my surround sound and the sound is really good. :thumbsup:
