HD or not to HD
Discussion in 'Plasma TVs' started by ff2001, Jun 20, 2003.
  1. ff2001
    ff2001
    Jun 19, 2003
    36
    Leamington Spa
    I am about to purchase a panny plasma TV PW5 but have found a good deal on the HD version £3500 is it woth getting the HD version?
    Would prefer the HD option but the connectivity could be an issue.
    It only comes with the vga socket, but could I run my equipment through RGB-VGA converters and then a VGA switch to select source? Equipment would be
    digital sky RGB-VGA
    XBOX }
    PS2 }
    DVD }
    Through amp
    How do you get from component / svideo to VGA?
    I currently own a sony str925 so do not NEED a new amp but would require svideo conversion. Could do with new amp for more optical sockets / multi room output anyway so maybe component output from the denon 3803
    Would {XBOX / PS2} - VGA converter be a better bet?. Could run DVD through another RGB - VGA and not require an amp.
    Thanks for any advice
    Lee
    Sony 28" WS, SONY STR925, Imerge Soundserver, marantz rc5000, XBOX, GC, PS2, B&W CM4, CMC and DM601 speakers
  2. JamesTapp
    JamesTapp
    Oct 2, 2002
    235
    16
    Bedfordshire
    Get an iScan Ultra. This has SVideo, Composite and Component inputs with a VGA output. Good prices at the moment because they are clearing the stock with the iScan logo. See www.ivojo.co.uk.
    StooMonster will be along shortly to tell you the great benefits that you will gain from this neat piece of kit.
    :D
    James
  3. Dutch
    Dutch
    Dec 5, 2002
    2,584
    3
    North Yorkshire
    +271
    Hi Lee,
    You should be able to fit a terminal board to the plasma which will give you component, s-video and composite. I think you can get them in BNC or RCA input socket flavours. You might need a component switcher if you need to input more than one component source. Sky into the VGA input (via a JS Tech converter) would be fine. Hope this helps.
    Steve
  4. JamesTapp
    JamesTapp
    Oct 2, 2002
    235
    16
    Bedfordshire
    Of course, the terminal board is an option, but you will always wonder if the deinterlacing of the iScan would have made a bigger difference to the quality of your display.
    Why not get one on loan before getting the terminal board... you know you want to....:devil:
