HD Movie Trailer Via Zbox 360
Discussion in 'Xbox Forums' started by ahaydock, Mar 26, 2006.
  1. ahaydock
    ahaydock
    Nov 16, 2005
    1,590
    Dorset
    +177
    Hi All,
    I have just bought a Xbox 360 Platinum and want to know how I can view HD Movire Trailers on my Panny 42PV500 :thumbsup:. I have searched the forums but get a bit confused :confused:. I am completley new to consoles so please forgive me. Also I do not have a PC, I use Macs.
    Can I download HD trailers of the net, then burn them to a CD or DVD to watch via the 360? Is it possible to dump on the HDD?
    Basically I want to show off my HD TV with some movie footage.
    Any help or links to relevant posts would be much appreicated :lease:
  2. MonkeyKnuckle
    MonkeyKnuckle
    Dec 8, 2005
    6,519
    Portsmouth
    +718
    if you connect your 360 to a broadband connection then you can download a few trailers.
  3. dllord
    dllord
    Sep 8, 2005
    1,054
    48
    +30
    You can only download the ones off Live marketplace tho, you won't be able to stream off your mac or burn to a DVD and watch them or anything like that!
  4. Munkey Boy
    Munkey Boy
    Nov 23, 2003
    16,960
    2
    2
    Manchester
    +4,473
    No point burning HD trailers to a SD DVD, they won't be HD anymore then. No, the only way to do it (unless you want to stream from a Windows XP Media Centre PC) is to download trailers from the Marketplace. They are free though.
  5. ahaydock
    ahaydock
    Nov 16, 2005
    1,590
    Dorset
    +177
    Thanks everyone - I will give it a go...
  6. gilford
    gilford
    Feb 12, 2005
    7,611
    Welsh riviera........
    +1,016
    If you have a wireless home network and/or modem, go and download a programme for your mac called Connect360. It costs $15 but it is amazing! It allows you to stream wirelessly your entire iTunes and iPhoto library to your 360 :):):)
    You wont beleive the quality of your pictures in true HD :)
    Good luck!
  7. Moogle
    Moogle
    Aug 28, 2005
    13,751
    London
    +1,398
    Doesn't do video though.
  8. ahaydock
    ahaydock
    Nov 16, 2005
    1,590
    Dorset
    +177
    Thanks for the help. Shame the Marketplace doesn't have that many HD movie trailers to choose from.
    How often do they update the trailers sections?
    I do have a wireless network so I will give the program a go.
    Thanks.
  9. Deleted member 92943
    where can i download hd trailers that can be streamed on media centre
  10. rEVILospud
    rEVILospud
    May 1, 2005
    2,295
    Shoreham-by-Sea
    +235
    There's quite a few available here. All in WMVHD format @ 720p or 1080p. Obviously the 1080p ones will be downscaled to the res your Xbox 360 is set to.
    You can also install hdtv pump here, and give the trailers on that site a go too (TP and TS formats).
  11. Deleted member 92943
    cheers mate. downloading some now
  12. Pebb
    Pebb
    Dec 29, 2005
    13,152
    Eastleigh
    +829
    Have you got a DVi socket on the back of your TV.
  13. Deleted member 92943
    na, just a vga
