HD Just fitted - multiple room problems
Discussion in 'Satellite TV, Sky TV & FreeSat' started by CraigDS, Sep 7, 2007.
  1. CraigDS
    CraigDS
    Mar 13, 2007
    3
    The house has always been setup so we can view (via. the coaxial socket in each room) the sky channel that is currently on. This has worked with both normal sky and then Sky+
    I have just had Sky HD installed today, installation went quickly and no problems with the setup downstairs. Have since come upstairs and I cannot view the Sky channel anymore.
    I have checked the cables in the back of the box, they are fine. And have tried finding the channel via tuning it in upstairs, no luck.
    Any idea?
  2. tonkie
    tonkie
    May 16, 2005
    3,686
    Guernsey
    +897
    Go to services then press 4,0,1 and select and then to 4, there you will see rf channel number make sure that is on 68 and make sure the rf outlet is on and save settings.
  3. CraigDS
    CraigDS
    Mar 13, 2007
    3
    Done that, RF Output wasnt on but was on 68. Turned it on but its still not coming through.
  4. Carlosv
    Carlosv
    Aug 15, 2004
    22
    3
    Glad its not just me then with this problem, on top of that I cannot get some (ITV, CVh4 etc) terrestrial digital channelson any digital sets I have connected when Sky is in the loop, if I disconnect the RF and pluig it directkly to the rest of the house, tehy are all there.
    I have tried both RF outputs and on different Rf channel output settings 9V on and off etc.
  5. eFGee
    eFGee
    Feb 2, 2007
    333
    West Sussex of England
    +13
    Had the same problem.
    Was told on here that it was probably due to HD being set to the same channel as terrestrial.
    Upon checking, sure enough HD and channel 4 were set to the same channel. After changing the HD channel and retuning in the tv, the problem was solved. Took about 20 mins to do all 4 tv's. (and I waited months before doing it...sheesh.)
    Hope that helps.
  6. CraigDS
    CraigDS
    Mar 13, 2007
    3
    that worked a treat.
    Now to go an retune all the TVs in the house!!
