HD Future connection issues
Discussion in 'Plasma TVs Forum' started by billandkez, Aug 27, 2005.
  1. billandkez
    billandkez
    Aug 21, 2005
    94
    Harlow, Essex
    +17
    Hi, I am considering buying the Panny TH42PV500 but I was wondering if it is futureproof as HD progresses. As it only has one HDMI connection I assume I will need to connect the new Sky HD box to this input but I was wondering that if I purchase a HD compatable DVD player in the future then can you still get HD definition through Component or RGB input or does it also need to be connected to a HDMI/DVI input in which case maybe I should consider the Hitachi 42PD7200 which has both a HDMI & DVI input? :lease:
  2. ukdan
    ukdan
    Feb 16, 2005
    1,135
    swindon
    +85
    You could wait for new av amps that will have multi hdmi switching.
  3. Badger0-0
    Badger0-0
    May 30, 2005
    20,593
    Spaghetti Junction (really)
    +1,921
    I believe the first SKY HD boxes will have component, so you could use that for SKY and the HDMI for DVD :thumbsup:
    The question then is will the next gen SKY boxes have component??
    Your guess is as good as anyone elses.
    UkDans suggestion is good too :smashin:
    EDIT:
    I forgot about HDCP so it will probably mean you will have to go through the HDMI at some stage.
  4. paulst10
    paulst10
    Dec 16, 2004
    12,151
    Essex
    +1,612
    octobers what hi-fi features a new HDMI switcher gefen HD 2 x 1 which lets you plug 2 HDMI inputs, and 1 output to the screen thats £176, "image quality seems to be unaffected" they say
  5. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Onkyo will have a mid priced HDMI switching amp in the autumn. I guess they will not be alone.
