HD Freeview
Discussion in 'Freeview & YouView' started by CGizzi, Jan 5, 2007.
  1. CGizzi
    CGizzi
    Jan 30, 2006
    341
    28
    +26
  2. Lunny73
    Lunny73
    I'd be sceptical about how good the scaler is for that price, especially when you factor in the cost of the HDD. Which TV would you be using it with? If it's a HDTV it's own scaler is probably better.
  3. Andy98765
    Andy98765
    Feb 15, 2006
    10,472
    2
    +1,365
  4. Lunny73
    Lunny73
    Humax PVR-9200T is popular too. Comes in at £100 cheaper than the evesham and will give as good a picture IMO. Do a Google/Froogle on it.;)
  5. Utumno
    Utumno
    Doesn't have HDMI out or upscale though ?
  6. bigtim
    bigtim
    Apr 5, 2005
    844
    28
    Cardiff
    +60
    Your HDTV will automatically upscale all inputs to the panel's resolution anyway. Only reason to use an external upscaler is if it does a better job - doubtful this evesham unit would (and unless your TV is 1920*1080 native then it would have to scale it again anyway).
