HD Freeview
Discussion in 'Freeview & YouView' started by scotchgitt, Mar 23, 2006.
  1. scotchgitt
    scotchgitt
    Mar 16, 2006
    19
    Tried a search but couldn't find the answer.
    Is there going to be a way to get HD from a freeview source.
    Sky will no dought charge a fortune, Cable won't be much better but is there a different option.
    Can it be obtained through broadband? or an HD ready freeview box?
    thanks
  2. Jowl
    Jowl
    Nov 2, 2005
    613
    28
    +27
    As I understand it (from asking a similar question on here) is that currently there isn't really enough capacity on Freeview to carry HD signals.
    When the analogue system is switched off, it should free up more capacity.
    Though I believe the BBC are trailing HD to the some London areas for the World Cup
  3. fabbers
    fabbers
    May 19, 2004
    128
    +10
  4. RichardBoult
    RichardBoult
    May 11, 2004
    671
    +18
    Whats that decoding then?
    Is MPEG2 High Def?
  5. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    I believe that is for satellite, it's a cut down version of the STB they supply for the German Premiere service. Judging from the serious lack of information (and I'm sure it is mpeg4) the product does not sit in their warehouse:)
    It's been mentioned over on DS.
  6. PhilipL
    PhilipL
    Jan 18, 2002
    3,855
    103
    +461
    MPEG 2 can be high definition, however it is thought the trials by the BBC will use MPEG4 due to better compression.
    In fact it is widely rumoured that there will be a second switch off sometime after 2012 where Freeview will switch to MPEG4, making all the current boxes obsolete! This is so we can have lots more QuizCall, Bid TV etc type channels pushed at us while still freeing even more airspace for the government to sell off.
    Regards
    Phil
  7. mapryan
    mapryan
    Feb 18, 2005
    37
  8. PhilipL
    PhilipL
    Jan 18, 2002
    3,855
    103
    +461
    I doubt it, it mentions nothing regarding support for MPEG4 which is most likely the format the BBC will use for high definition.
    A lot of existing Freeview boxes support MPEG2 at HD resolution, there is nothing special about that card. Maybe in America they get MPEG2 HD broadcasts, but I think it is unlikely to be MPEG2 over here.
    Regards
    Phil
