HD-EP35 - Using analogue outs and subwoofer
socrates1
If I set the speakers to large and subwoofer to yes, will the player only send the LFE channel to the subwoofer and not any of the other low frequency elements. The subwoofer still shows crossover level choices when subwoofer is set to yes. I only want the .1 to go the subwoofer.
a4lloxo
hi mate,you need to set to small if you only want bass from the sub.id also set your crossover to 80hz and turn the crossover on the rear of your sub to maximum.also enable +10db setting on the analogue stage of your av amp:thumbsup:
Podcast: Best Hi-Fi products of 2020, Plus Best of the Month for TV Shows & Movies
