HD-E1 problem with Panasonic SAHT855
Discussion in 'Blu-ray & DVD Players & Recorders' started by SGH42, Dec 21, 2006.
  1. SGH42
    SGH42
    Aug 13, 2004
    639
    +11
    I have mine setup & running & it looks great ! One thing though, I have it connected via optical to my Panasonic SCHT855 & it sounds like surround sound but the HD-E1 only shows 2 channel on the front display, any ideas ?
    I have selected Digital Out SPDIF Bitstream in the HD-E1 audio set up but no sound comes through the Panny, I can get 2 channel sound by selecting Digital Out SPDIF PCM.
    Help !
    Steve
  2. Dave2
    Dave2
    Sep 9, 2006
    3,965
    Newcastle Upon Tyne
    +529
    does the panny support DTS if it does not then you can not get the bitstream through and the pcm only supports 2 ch.
  3. SGH42
    SGH42
    Aug 13, 2004
    639
    +11
    Hi Dave,
    Yes it does support DTS, I'm thinking it can't be the lead as it's allowing sound through using pcm ?
    Steve
  4. GPMCDERM
    GPMCDERM
    Dec 12, 2002
    109
    Check the manual...if your panny is an all in one job then it mightn't decode DTS through the optical in...I have the panny HT900 and while it will decode a DTS bitstream from the onboard DVD player it won't decode it through the optical input(trust me found out the bad way)
  5. SGH42
    SGH42
    Aug 13, 2004
    639
    +11
    Thanks (I think !) GPMCDERM
    I think that sounds like the most likely thing, really fed up with that. Might have to get a new surround system that does decode DTS, anyone know of any decent ones.
    Steve
  6. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    decent ones will come in as a separate amp, choose your own speakers. 99% of all in ones are nobbled in some way. I refuse to sell them for this reason, people often ask. You always end up regretting such a purchase, especially if it says 'Bose' on the front.... Go get a surround amp from Denon, Onkyo, Pioneer or Yamaha, in alphabetical order, not quality order necessarily. Ideally it should have analogue multi channel input as well as coax/optical in.
  7. SGH42
    SGH42
    Aug 13, 2004
    639
    +11
    Any suggestions on a good model number to get ? I don't want to spend a mint though ! & would preferably want to use my panny speakers, all I want is 5.1 from my HD-E1 & 5.1 from Sky HD.
    Steve
