HD dvds dont work???
valleyboy22
Hi all,
i got a samsung HT TZ215 home cinema system wiv a hdmi output,so thouht it would play HD dvds but they dont work?i thought the whole point of a hdmi output was for the dvd player to play HD dvds,but mine dont??HELP!!!!
V-Boy:confused:
kj23
Hi all,
V-Boy:confused:
you need an hddvd player to play hddvd's. seems like you can upscale with your new equipment though.
MeanDorris
Sorry,
Your player will not play HD DVD's or Blu Ray (the two hi def disc formats).
the HDMI port is just a type of digital connection standard which you need to use if you want 1080p hi def connections with hi def audio but can also be used to carry standard def pictures and sound.
The formats your dvd player will support are the following:
Playback compatible formats are CD , CD-R , CD+R , CD-RW , CD+RW , DVD , DVD-R , DVD+R , DVD-RW , DVD+RW , MP3 , JPEG , WMA , DIVX (MPEG4).
You will need to buy a specific blu ray or HD DVD player (I a am sure you are aware that the hd dvd format is "dead" - however you can pick up some very cheap hd dvd films at the moment if you can get hold of a second hand player) if you want to spin those formats.
valleyboy22
:)Thanks all for reply,and yeah it does upscale,but presume it does it automatically through the hdmi leads i got connected,but if it dont any help on this wud be great thanks.will prob go for blu ray dvd player as know that hd ones are dying off.
Ralphy1981
You can't buy HD DVD players new anymore mate, it's a dead format.
Get yourself a Sony 350 Blu Ray player. A bargain at £250.
