Hd Dvd?
Discussion in 'Blu-ray & DVD discs' started by Murray, Nov 21, 2004.
  1. Murray
    Murray
    Nov 12, 2004
    194
    Auckland
    +3
    Is there any High Definition DVD's available yet? I have a Panasonic AE700 projector and an HDMI Pioneer DV S969AVi player and wanted to see how good it could really look? Lots of the DVD's still look pretty poor even with good equipment. :mad:
  2. recruit
    recruit
    I think there has been some releases in Japan but not anywhere else yet, it will take time :(
    John
  3. AML
    AML
    Jul 22, 2004
    4,989
    Tokyo
    +229
    If you want to use HD DVD or Blu Ray you will need a new player. HDDVD Disks wont work with current DVD players. No matter how new they are or if they use DVi or HDMI.
    Its a different format. Blu Ray being the superior format.
  4. Roughneck1
    Roughneck1
    Isn't Terminator 2 (R1) High Def? Also Island Fever 3 (adult XXX) is the first true Region 0 Hi Def disc.
  5. recruit
    recruit
    I Like the Idea of Adult Entertainment being in Hi Def :D
    John :)
  6. the_pauley
    the_pauley
    Nov 7, 2002
    4,066
    +198
    Mmm! Touchy-feely! :thumbsup:
  7. AML
    AML
    Jul 22, 2004
    4,989
    Tokyo
    +229
    Craig. I beleive the source for the DVD is Hi def, but I dont think they could actually fit the entire high def movie on a DVD because it would need more space. Hence the need for Blu Ray and HD DVD.
    In reality there shouldnt be a need to change the format, but like I said, there simply isnt enough space on a DVD to fit a fully HD movie plus all the extras and a DTS/DD mix.
    Its cheaper in the long run to have a new format.
  8. Dutch
    Dutch
    Dec 5, 2002
    2,598
    3
    North Yorkshire
    +282
    AML,
    T2 HD, Island Fever 3 and quite a few more (mostly IMAX) titles are encoded in Microsoft's VC-9 codec - recently renamed SMPTE VC-1 for use on HD DVD and Blu-ray. They run at lower bitrates to stay under DVD's red laser limit of 10Mbps. For next gen blue laser, they should be using rates of around 16Mbps. :) Hope this helps.
    Steve
  9. recruit
    recruit
    Do any of you guy's know when it these new formats will be released in the UK or can we already get them?
    John
  10. xenon
    xenon
    May 7, 2003
    65
    11
    +3
    A german site has Underworld, Timeline, The Italian Job, the two Lara Croft films and a few others up for order. Also, Amazon.de (Search for "WMV-HD") has most of them, they work out a bit cheaper too. They are all 720P.
  11. BrianC
    BrianC
    Jan 20, 2003
    2,190
    +101
    Do the german releases (assuming they are proper region 2 German releases, not the imported Region 1 versions) require that the disk is registered online before it can be played in your PC?
  12. xenon
    xenon
    May 7, 2003
    65
    11
    +3
    I think the DRM is on the DVD so you don't go online. A bit like the BMW 'The Hire' shorts on 'Do Amazing Things XP', or those 'Corel Adventure With Space Dolphins' Imax DVD things. As to what the DRM checks on your system, I'm not entirely sure, but at a guess I think it would play on any PC (that satisfies the hefty processing requirements to ensure you don't end up in flick-book land). Maybe worth waiting until someone confirms though.
  13. Murray
    Murray
    Nov 12, 2004
    194
    Auckland
    +3
    Will the WMV-HD disks play HD through my Panasonic 700 and my Pioneer DV S969AVi player with HDMI. I can play through HDMI in 720p and 1080i. Interested in seeing true HD to test the setup. :smashin:
  14. xenon
    xenon
    May 7, 2003
    65
    11
    +3
    They won't I'm afraid. I guess I saw mention of T2 and the fact that it's WMV-HD got me talking about these new releases, and made me forget about the fact that you're not going to be using a PC. I hear the Kiss DP-600 will play WMV-HD. I don't know of any other HD material on a normal DVD.
  15. oxygenuk
    oxygenuk
    Sep 12, 2004
    1,644
    38
    +13
    Can somebody please state weva hddvd will only be hdmi dvi compatible or will you be able to use rgb scart with it too?
  16. Rasczak
    Rasczak
    Apr 3, 2002
    21,241
    Warwick
    +2,282
    It will depend upon the players - but you won't be able to watch High Def content via RGB Scart - it will need to be component, HDMI or DVI-HDCP. Whether component output is used due to piracy concerns remains to be seen...
  17. oxygenuk
    oxygenuk
    Sep 12, 2004
    1,644
    38
    +13
    but how about people with widescreens like me that doesnt have hdmi and dvi inputs, surely a hddvd in rgb would look better than standard dvd in rgb?
