hd-dvd playback a little stuttery
hi all hoping some one can help me with this small problem , when playing hd-dvd's thru my htpc the sound is fine but the picture seems to jump a little (stutter) , this is the same with blu-ray but both run fine when not on full screen - if i only play them in half screen then there is no choppyness at all
also when i copy hd-dvd or blu-ray to harddrive - how do i get it to play
all help greatly appreciated
cheers afk
i have the following
GGC-H20L blu-ray / hd rom drive and powerdvd ultra 7
Gigabyte GA-73PVM-S2H
retail E6600 2.4 GHz, 4MB L2 Cache, 1066MHz FSB
western digital 320gb hard drive
1TB samsung spinpoint f1 hdd
running thru hdmi on toshiba 42" 1080p lcd
powerdvd ultra gives this in information tab
Player Information:
Player Region Code: Not Specified
Current Drive: D:
Title Region Code: Not Available
Audio Attributes: Not Available
Hardware Information:
Processor: Intel(R) Core(TM)2 CPU 6600 @ running at 2399 MHz
3DNow! Technology: Not Detected
Enhanced 3DNow! Technology: Not Detected
3DNow! Professional Technology: Not Detected
IA MMX Technology: In Use
IA Streaming SIMD Extensions: In Use
IA SSE 2: In Use
Video Accelerator: DirectX VA (not in use)
Multispeaker Audio Device: Digital Output (NVIDIA HDMI Aud (not in use)
SPDIF Output Device: Digital Output (NVIDIA HDMI Aud (not in use)
i have just used cyberlink advisor and here is the result , if it helps
this is the one only one not green on the advisor - Graphics Card : NVIDIA GeForce 7100 / NVIDIA nForce 630i No More Info (i have onboard graphics and not a seperate graphics card)
Check Item HD DVD Ready? Info
Processor : Intel(R) Core(TM)2 CPU 6600 @ 2.40GHz Yes
__dwItemID=1001__ : szLibCPUName = Intel(R) Core(TM)2 CPU 6600 @
__dwItemID=1002__ : dwLibClockRate = 2391
__dwItemID=1003__ : dwLibFamily = 6, dwLibModel=15, dwLibStepping=6
__dwItemID=1004__ : dwLibNumPhysicalProc = 2, dwLibNumCorePerPackage=2, dwLibNumLogicalPerCore=0
__dwItemID=1005__ : dwLibCorePerPackage = 2, dwLibTotalLogicals=2
__dwItemID=1006__ : szWMIName=Intel(R) Core(TM)2 CPU 6600 @ 2.40GHz
__dwItemID=1007__ : szWMIManufacturer=GenuineIntel
__dwItemID=1008__ : dwWMIMaxClockSpeed=2400
__dwItemID=1009__ : bBatteryExist=0
__dwItemID=1010__ : szGuess=Core Duo TXX (Conroe)
System Memory : 1792 MB Yes
Operating System : Windows Vista Service Pack 1 Yes
__dwItemID=1301__ : Adapter Compatibility: NVIDIA
__dwItemID=1302__ : VideoProcessor: GeForce 7100 / NVIDIA nForce 630i
Graphics card video memory : 256 MB
Graphics Card Driver : 7.15.11.6375 Yes
__dwItemID=1501__ : 2D Driver=7.15.11.6375
__dwItemID=1502__ : COPP=Yes
__dwItemID=1503__ : RGBOverlay=Yes
__dwItemID=1504__ : DEVICE=N/A
__dwItemID=1601__ : Driver 0:
__dwItemID=1602__ : [D:] HL-DT-ST BDDVDRW GGC-H20L
__dwItemID=1603__ : eHCMDrvType=0x01846fc7
__dwItemID=1604__ : CDRom=1 DVDRom=1 BDRom=1 HDDVDRom=1
HD DVD Drive : [D:] HL-DT-ST BDDVDRW GGC-H20L Yes
Software Player : PowerDVD 7.3.3730c.0 Yes
Video Connection Type : Digital(with HDCP) Yes
Program version : 1.0.1801.0
System language : 0809 ENG English English
Time : Wed Sep 24 20:39:21 2008
Computer : Desktop
System Name : OWNER-PC
socom23
Your onboard graphics isn't up to the job.
hi and thanks
if thats the case why do they play fine on 1/2 to 3/4 screen and then get a little stuttery on full screen , it is nothing major and is well watchable but obviously i want to get rid of the stutter.
if i need to get a seperate graphics card what would anyone suggest , i would still like to be able to run thru hdmi but will use dvi if i have to
cheers afk
Its definately the card as suggested. File based playback is handled by your CPU, and optical based (and possibly ISO based as well...) is handled by the GPU.
I use a passively cooled 3470, and even a 3450 (at around £25) will be enough. Not sure of the NVidia equivalent.
thanks for that m8 , any chance you could send me a link to those 2 (passively cooled 3470, and even a 3450) and are these suitable for my system , i have searched for both but seem to find different ones so not sure which they are
cheers afk
MikeK
Pretty much any of the ATI HD series PCIe graphics cards would be OK - the 3450 is probably the one to go for at the moment based on price though, but 3650s can be had for just £10 or so more.
However, if you use audio over HDMI, be aware that most ATI cards do not have a HDMI socket - they use a DVI socket with a special ATI DVI-HDMI adapter. The kicker is that many cards do not come with the adapter, so you need to do your homework (which isn't easy, as many manufacturers fail to bother mentioning whether it's included or not).
This one
http://www.microdirect.co.uk/(31428)Sapphire-ATi-Radeon-HD-3450-256MB-DDR2-PCIE.aspx
seems to indicate the the HDMI adapter is included (but double check if it's important for you)
What are the CPU usage levels at when you see the stutter?
Are these stutters in the same place every time?
It could just be that your CPU isn't quite powerful enough to cope with HDDVD/BD playback without any assitance from a graphics card.
Have you tried a mild overclock of your CPU?
This is the 3470 I have. Passively cooled, and comes with the DVI to HDMi adaptor.
And has droped £15 in price since I bought mine 6 months ago.:smashin:
No worries mate, glad to help. :smashin:
