HD DVD HDCP in to our pj's
Discussion in 'Projectors, Screens & Video Processors' started by 008, Jan 16, 2005.
  1. 008
    008
    Nov 13, 2002
    400
    kent
    +15
    With upcoming HD DVD's which I assume will have HDCP, how are we going to get the image to work with our non HDCP devices ? I cant beleive this will only benefit the LCD DLP brigade. Any ideas ?
  2. Vince M
    Vince M
    Nov 2, 2004
    473
    19
    Lagoa
    simple solution,HDCP is only on digital outputs/inputs NOT on component,-for a crt you would output via component into a top grade transcoder to RGB.(one that doesnt crush the grey scale like the Keeene cheap and cheefuls..)-and a transcoder that accepts 720p and 1080i(the Keene ones dont.).Then into your crt by vga to 5bnc.
    Alternatively,use the HDTV passthrough on something like the I-Scan HD.
    The problem comes if HD-DVD & Blueray dont offer a component output!
  3. Jonesthegas
    Jonesthegas
    Jun 5, 2002
    633
    Newcastle upon Tyne
    +19
