HD-DVD drive the answer to ** NOISE **
Discussion in 'Xbox Forums' started by rommi, Dec 23, 2006.
  1. rommi
    rommi
    Jun 28, 2002
    257
    +5
    I love my 360. But its NOISY !
    Am I right in thinking you can run a game disk off the new HD-DVD drive?
    I hear the new drive is very quiet.
    So, will having the new HD-DVD drive quiten down my 360 experience?
    It would be worth 130 quid for that, let alone some movie improvements :)
  2. dannius
    dannius
    Feb 12, 2006
    3,401
    +349
    You can't run games from the HD DVD drive.
  3. lord-dudester
    lord-dudester
    Oct 27, 2006
    2,232
    Spalding Lincs
    +269
    is this not planned in an update though? im sure i've read/heard somewhere it was?
  4. Deleted member 92943
    I would be happy if that was an option in the future
  5. m1ket
    m1ket
    Aug 24, 2005
    3,694
    UK
    +332
    doubtful becuase the transfer rte of the hd-dvd while more than good enough for movies is not as fast as the internal dvd drive
  6. mannyo
    mannyo
    Feb 6, 2005
    758
    28
    Blandford Forum
    +77
    as m1ket has said, I dont think it will happen because of the data transfer rate. USB2 is way slower than the internal drive controller. Even if it did work, games would take much longer to load and gameplay would be interesting to say the least.
  7. originalbadboy
    originalbadboy
    Mar 27, 2003
    239
    +3
    Even if it did happen, the chances are the drive would have to spin up to the same speed as the internal drive, hence more noise.
    The reason why the HD-DVD drive is so quiet is because their read speed is 1X, so the discs are not spinning no where near as fast.
  8. MickyGee
    MickyGee
    Jan 6, 2005
    294
    Preston
    Unless your HD DVD drive has a noisy fan like mine...
  9. lansalot
    lansalot
    Jan 31, 2005
    96
    +7
    Hmm. USB2 = 480mbps. SATA (hd) = 150mbps.
  10. lrbh
    lrbh
    Oct 8, 2005
    212
    Egersund
    +7
    You're wrong..
    USB2.0 = 480 Mbps (Megabit Per Second)
    SATA 150 = 1.5 Gb/s (Gigabit Per Second, ~1500 Mbps)
    SATA 300 = 3.0 Gb/s (Gigabit Per Second, ~3000 Mbps)
  11. Ian_S
    Ian_S
    Dec 29, 2005
    7,163
    163
    +2,198
    DVD at 16x is approx. 22MB/s
    HD-DVD at 1x is approx 36Mbps = ~4.5MB/s
    USB 2.0 = 480Mbps = ~60MB/s
    USB 2.0 would have more than enough headroom for most PC hard-drives, and certainly ALL current optical drives.
    I would be surprised if an Xbox 360 used SATA for optical connection when a cheaper IDE solution would be more than adequate. As for the HD-DVD drive itself, I don't know what the maximum DVD read speed would be and whether it is as fast or faster than the built in DVD drive.
  12. Member 55145
    Member 55145
    Jan 18, 2005
    12,082
    +3,481
    more interesting would be if you could crack open the 360 and replace it with the hd-dvd drive. my warrenty is now out of date so i wouldnt mind replacing the drive if itd work
    anyone know if anyone has tried it yet?
  13. lansalot
    lansalot
    Jan 31, 2005
    96
    +7
    Oops. I'll blame that one on typing when I should be sleeping :p
