HD-DVD 360 developer interview
rover2002
No HDMI then.They also don't mention if the unit up converts SD-DVD to 1080P.
PlexShaw
Given that the 360 only goes up to 1080i anyway, why would you expect it to do that? Or am I asking a thicko question? :confused:
rover2002
It would be an added bonus, although i really doubt it will have.It will be a bare bones player at the end of the day to keep the cost down, still it should make a good gift.
richard plumb
I think - even though lack of ICT flag allows HD output - that there is another flag that limits component to 1080i (even though technically it could handle 1080p)
AgentCool
I think most 360 owners (myself included) will only want a 1080i output anyway because that is all their TV can handle. If you had invested in a 1080p set, chances are you'd be willing to purchase a stand-alone player instead of a cheap add-on.
Angry the Clown
That's correct, yes. The core AACS copy protection system itself is the limiting factor in allowing (or in this case not allowing) anything beyond 1080i over component on both HD DVD and Blu Ray.
danvitale
Theres the regulation also that prohibits SD DVD upscaling out of Component.. but theres nothing stopping upscaling via VGA.
rover2002
Now i think about it i have read somewhere that the DVD does indeed upscale over VGA, not sure if it was here or another forum:D
richard plumb
yes, so we'll have the crazy situation where you can watch native HD movies in 1080i, but SD DVD stays limited to 480/576p. :rolleyes:
IdealDeek
I thought the comments about the visual differences between componant/vga & hdmi were interesting, claiming it's negligable & in some cases worse. I can't really tell any difference between SkyHD thru hdmi & movie trailers via vga from the 360 but thought that was just me!
My TV only has x1 hdmi anyway & those multi adaptors seem expensive. Has HDCP been shelved for now then?
richard plumb
marketing spin to cover the fact that they don't have HDMI out. Component *is* fine, but their reasoning was a little suspect.
Didn't answer my questions though:
1) Will the HDDVD drive be region free?
2) Will a US HDDVD drive work on a UK Xbox 360 and let me play US HDDVDs?
3) Will the HDDVD drive play DVDs?
4) Would a US HDDVD drive let me play R1 DVDs on a UK machine? (so I effectively have a multiregion player)
5) Will you be supporting all the advanced audio codecs sent over optical out?
Rasczak
Did I read correctly that the Xbox 360 HD DVD drive connects via a simple USB connection? If so I wonder if it can be connected to a PC as well?
richard plumb
they've dodged that one. In theory yes, but then you'd need the software on the PC, whereas with the 360 it'll come via a dashboard update online.
I guess it could be done but it might depend on whether they are subsidising the drive to push 360s, or whether the deal with Toshiba means keeping away from PCs (eg get cheaper drives?)
Evil Engineer
If it's a standard PC drive in a plastic case then a few seconds of brute force and ignorance could provide you with a very cheap HD DVD drive for your computer. :)
BillBlank
I haven't seen such an apropriate username for ages :rotfl:
Just how many sets of club hammers do you own sir?
A
Ajazz 87
So a question to you then. If I play a DVD in my xbox 360, would it not be upscaled at all?
I did hear something once mentioning that DVD's are filmed in a higher resolution to what we see when using a DVD player. What is the resolution and would we receive that when playing through the xbox 360?
NackNack
Only using VGA will you get an upscaled picture through a 360.
Films are filmed at very high resolutions (something like 3000 x 2000), but are transfered to 720 x 576 for PAL DVDs.
Through VGA the highest we can get an upscaled picture to 1360 x 768.
A
Ajazz 87
Aww so when using component, I will acheive 720x576 (native). What would it be when using a standard DVD player if you don't mind me asking?
If when using a VGA, will the image automaticly upscale to 1360x768?
NackNack
It upscales to whatever resolution you have set the VGA cable to output. :)
A standard DVD player will be 720 x 576 if it doesn't upscale or 720p if it does (1280 x 720). I think some upscale to 1080i too (1920 x 1080).
Rasczak
According to this thread Xbox magazine is showing pictures of a new Xbox 360 with an HDMI connection on the back. I wonder if this could mean an integrated HDMI/HD DVD Xbox 360 is inbound?
Similar threads
Trending threads
Latest News
NAD launches T 758 V3i surround sound receiver
  • By Andy Bassett
  • Published
Sky unveils next tranche of HDR content
  • By Andy Bassett
  • Published
Acoustic Energy launches AE520 flagship speakers
  • By Andy Bassett
  • Published
Disney drops all 20th Century Fox branding
  • By Andy Bassett
  • Published
Kitsound launches Funk 25 wireless earphones
  • By Andy Bassett
  • Published
