HD Download playback help!
Discussion in 'General TV Discussions Forum' started by Shooter1, Oct 13, 2005.
  1. Shooter1
    Shooter1
    Feb 15, 2005
    2,305
    +181
    Hi everyone
    I'm a complete novice to this downloading lark, so please bear with me.
    I managed to a download some HD material.
    When I ty to play it with windows media player I get the following message:
    Windows Media Player cannot play the file. One or more codecs required to play the file could notbe found.
    Can someone help me please, I'm desperate to watch some HD material.
    IM running WMP 10 on XP home SP2
    [Edited - Kramer]
  2. robertjackson
    robertjackson
    do some more reading
  3. phillfyspoon
    phillfyspoon
    Oct 21, 2003
    2,149
    Hampshire
    +76
    It may not even be HD some just have HDTV in there name to say it was ripped from hdtv it would have to be at least 1gb
  4. Johndm
    Johndm
    Jan 25, 2003
    1,832
    Bedford UK
    +67
    some clips available here http://www.wmvhd.com/
    that should give you the idea... :D
  5. beasty54
    beasty54
    Mar 16, 2005
    6,189
    Lincoln
    +527
    Its not really high definition at all, these files are just copied from a high definition source but then the bit rate is lowered to make it a much smaller file. Also i should probably remind you that downloading such files is illegal and not allowed on theses forums so be careful
  6. dan1979
    dan1979
    Sep 16, 2004
    3,539
    83
    +218
    It definitely isn't true HD, it will be around 700MB and about 960x528 resolution wise.
    The answer to your question is probably in the name, you don't have the Xvid codec installed.
    Try that and if you still have issues download a prog called Gspot which will scan the file and tell you what codecs are missing
  7. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    You probably need the latest xvid codec, do a google:)
    Install the codec and it should then play fine and as mentioned the cap isn't HD just a higher than normal resolution and is capped from a HD source.
  8. dan1979
    dan1979
    Sep 16, 2004
    3,539
    83
    +218
    You might also need AC3filter installed...
  9. Johndm
    Johndm
    Jan 25, 2003
    1,832
    Bedford UK
    +67
    You could also buy T2 Extreme Edition R1
    Bit of a pain to get it running though... :D
  10. Shooter1
    Shooter1
    Feb 15, 2005
    2,305
    +181
    THanks for all the positive comments.
    I've downloaded the latest xvid codec and ac3 filter but it still doesnt work.
    I ran the gspot software and when I render the file it says that directshow was unable to play the file.
    Any ideas.
  11. dgc
    dgc
    May 1, 2003
    216
    Install "media player classic" and "ffdshow" (both freeware) and it should then play fine.
  12. Stephen Neal
    Stephen Neal
    Mar 29, 2003
    6,595
    +920
    VLC Player from www.videolan.org is also a useful player that copes with a lot of formats, and even broken/partial files, pretty well.
