HD DirectTV Connectivitiy Question
Discussion in 'Satellite TV, Sky TV & FreeSat' started by jeffatjlefko.co, Sep 5, 2004.
  1. jeffatjlefko.co
    jeffatjlefko.co
    Excuse the stupid question but I have been bitten by this with cable twice now.
    When you buy an HD box with the HD programming from DirectTV does both non-HD and HD signal come through on the same connection with a quality picture.
    I had cable installed by Comcast and TimeWarner and the HD programming had to be watched on one video source output, while non-HD had to be watched on another. Very annoying.
  2. AV Junky
    AV Junky
    Oct 30, 2002
    1,215
    Staffordshire, UK
    +69
    You do know this is a UK based forum, don't you?
    Better to post this over on AVS forum, which is US based.
  3. p0kerm0n2004
    p0kerm0n2004
    Mar 27, 2004
    131
    +11
    He's just trying to make us jealous :rolleyes:
  4. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,278
    Manchester
    +761
    As others have pointed out, this is the wrong place to ask.
    I do know that some USA HD STBs do indeed have separate outputs for HD (often via DVI or component video) and analogue ; thus what you have may well be quite normal.
    Chris Muriel, Manchester, UK
