Hd-d45 - Spdif
Discussion in 'General TV Discussions Forum' started by Dan-uk, Aug 2, 2005.
  1. Dan-uk
    Dan-uk
    Jul 10, 2005
    39
    Hi bit stuck with the whole SPDIF thing
    I have 2 belden 1694a coxial cables, one going from the DVD digital out to the SPDIF IN on the HD-D45, the other going from SPDIF OUT to the AMP Digital IN = No sound
    Either coaxial cable direct from DVD to AMP = Sound OK
    Coaxial from dvd to HD-D45 then I get sound from TV Speakers
    So.... have a got a dodgy SPDIF OUT ? on the TV
    any advice much appreciated
    Dan
  2. Den_Lyon
    Den_Lyon
    Jan 27, 2005
    25
    Dan,
    you have to tell the HD-D45 which video source you want to sync the sound to.
    Also, I was only able to use the "cd digital in" on my Yamaha AV1 amp.. the "DVD / Laserdisc digital in" didn't work for some reason (not faulty.. just an incorrect signal)
    Hope this helps
    Den
  3. Dan-uk
    Dan-uk
    Jul 10, 2005
    39
    Have defo got the Sagem SPDIF source to be AV5 (coponent ) will try the CD Digital in as my amp is quite old
    Thanks for the advice
