HD clips onto a DVD disk?
Discussion in 'General TV Discussions Forum' started by Joe Pineapples, Jan 13, 2005.
  1. Joe Pineapples
    Joe Pineapples
    Oct 23, 2001
    7,352
    Doncaster
    +1,134
    Downloaded a lot of the 720 and 1080 clips and watched them on the monitor. Went into Sevenoaks today and they have the HD ready Pioneer 50 & 43 plasma's connected, with HD dvd players (arcam)
    Is there a way to put the downloaded clips onto a dvd in a format the player will rcognise as HD, or would this lose the quality?.
    cheers
    joe
  2. Razor
    Razor
    Dec 15, 2004
    37,566
    2
    +12,434
    I think you just record it as data and the dvd decodes it. Nero should do it.
  3. Stephen Neal
    Stephen Neal
    Mar 29, 2003
    6,334
    +806
    Aren't the Arcam players just SD DVD players with on-board HD upconversion? (Or do they play HD MPEG2,4 or VC-1/WM9 video as well?)
  4. SamirP
    SamirP
    Apr 28, 2003
    1,303
    South Of The River
    +38
    Yes they just upscale SD to HD (720p & 1080i)
  5. Stephen Neal
    Stephen Neal
    Mar 29, 2003
    6,334
    +806
    That is what I thought - so they are really SD (480/576) DVD players with HD outputs - not to be confused with DVD players that can replay HD content which is natively 720/1080.
    I think we'll have to wait for HD-DVD (the standard) or BluRay, for full HD replay from a DVD-style machine.
  6. RecordablDVDfan
    RecordablDVDfan
    Aug 13, 2003
    2,902
    68
    +49
    Does'nt the new Panasonic S97 show full HD DVD ? It seems to play any format around at the moment incl DVD RAM and any MPEG 4 / Divx format, what can't it play ?! Anyone got a good price for this btw ?
  7. Stephen Neal
    Stephen Neal
    Mar 29, 2003
    6,334
    +806
    AFAIK there are now DVD players on the market that support the new HD-DVD spec, nor are there any HD-DVDs available to play on them. (AIUI HD-DVD requires support for MPEG2, MPEG4 AVC H264 and VC-1 aka Windows Media)
    The Panasonic player may support Divx, MPEG4, MPEG2 etc. - but whether it supports playback of HD files (rather than scaled SD playback for an HD display) I don't know. I very much doubt it supports full HD-DVD compliant replay though - as I don't believe any HD-DVD players have yet been released.
    There ARE BluRay recorders on sale in Japan, to record HD off-air transmissions, but I don't think these will be compatible with all versions the new pre-recorded BluRay DVD standard, as they won't contain support for the new codecs added?
  8. jasonl
    jasonl
    Aug 11, 2004
    147
    +3
    there are Hidef Divx trailers available in their website at the moment, you can burn them into a dvd and see if the panasonic can read the divx file and play the trailers in HD
    you can do this with a modded xbox and xbmc (slightly OT)
    hth
  9. sgauntlett
    sgauntlett
    Wouldn't it be easier to take along a laptop with the clips encoded (WMV9, Nero AVC, DivX etc etc) and play them back either VGA or DVI (if you've got a nice laptop!)??
