HD Channels on Sichbo
pedro2000uk
Should I be able to get HD channesl on Sichbo? (I can't). How can I receive them?
Is that a satellite receiver or iptv / streaming device/card, .....
edit - its a pc sw based pvr for a pc dvb-s or dvb-t card
Pedro it is PVR software/app for DVB T and DVB S signals.
To the OP what device are you using it on and what is it connected to - Terrestrial aerial OR satellite dish? What is your location?
logiciel
Why have you posted in Satellite - and what is your location?
pedro2000uk
Are the elements in your aerial vertical or horizontal
pedro2000uk
How would I tell?
Just look at it, if it's vertical it may be the HD are not there as you are just on a local fill in transmitter, not a main one, although they can still have the HD as well but some might not.
logiciel
I thought perhaps the name was a coincidence!
TJT1
and I'm in Yorkshire.
I think that when you were asked your location, it was hoped that you might give a more precise location in order that they could have a stab at which transmitter you were likely to be receiving and 'Yorkshire' is a pretty big county. Do you happen to know which transmitter you are receiving from, or at least the RF channel number of one of the broadcast channels (LCN)?
pedro2000uk
grahamlthompson
All relays have the PSB3 HD mux. However DVB-T2 is required for HD in the UK. DVB-T will only give you SD mux.
pedro2000uk
All .. they've been busy but I suppose by now they should have, there's some really tiny rural fill-ins.
grahamlthompson
All .. they've been busy but I suppose by now they should have, there's some rearly tiny rural fill-ins.
We have a really low power one in Redditch just for one estate, it has the HD mux. I get my Freeview from a relay which is part of a SFN (Lark Stoke) it has the 6 full 6 mux but not COM 7 or 8.
Sutton Coldfield is a problem because of tall trees at the bottom of our garden.
Incidentally there a few relays that are horizontally polarised.
I am putting the same aerial feed through my HDTV USB DVB-T as my TV receives which does get HD TV. Bilsdale transmitter BTW
TJT1
You have to have a T2 capable device to process Freeview HD stuff.
TJT1
They might not be globally wrong as there may be HD transmissions in T somewhere, but all the terrestrial HD transmissions in UK are T2.
However, having said that, it might be thr 'T' that is wrong and it's actually T2 and can decode UK HD stuff.
I'll tell you what. As you have one, you tell us whether it's HD or not. The TV will often give the resolution on the 'info' page. And if it will tune/decode the BBC B Mux, it's obviously a T2 device.
TJT1
Yes, I appreciate that, but when watching from and external device such as your stick, some TVs give the parameters of the signal that you are watching. Full HD will likely be flagged at 1080i or 720i
OK, let's try something different. On your stick, can you receive any HD TV? If so, it's T2 capable. If you can't then it's T.
TJT1
No this is what I am saying. The stick says HDTV but doesn't detect any HD channels.
That's the first time you have actually said that you can't get HD. You have previously just asked if it should.
Then it's not a T2, just like it says on the tin and, as we have said before, you need a T2 device for UK HD.
Latest News
Piega launches Ace Wireless speakers
  • By Andy Bassett
  • Published
M&K Sound launches V+ Series subwoofers
  • By Andy Bassett
  • Published
Denon launches DHT-S517 Dolby Atmos soundbar
  • By Andy Bassett
  • Published
Perlisten Audio launches loudspeaker ranges in UK
  • By Andy Bassett
  • Published
What's new on UK streaming services for February 2022
  • By Andy Bassett
  • Published
