HD Camcorders Space
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by speagle, Jan 16, 2008.
  1. speagle
    speagle
    I've been asked to buy a Camcorder as a present with around £300 to spend.
    I've been reading this forum and have been very grateful for the amount of great info given. However, I can't decide whether or not to go for a miniDV or HDD camcorder.
    The question I wanted to ask is about the amount of storage on a HDD camcorder. For example, a 30gb Sony DCR-SR32 states 20hrs 50mins. I assume this is highly compressed (low quality).
    Can anyone advice what can I expect on 30gb when the camera is set to a low compression (high quality) ?
    I'm trying to figure out how likely it is to fill up the camera on a two/three week holiday where downloading to a computer is not possible, at least with tape you can just stick a new tape in!
    Any advice would be very much appreciated.
    Ian.
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,533
    Rainham Essex
    +2,517
    I assume you mean HDD cam (Hard Disc Drive) rather than HD (High Definition) as I don't think you will find a half decent HD cam for your budget of £300.
    Mark.
  3. speagle
    speagle
    Yes meant a HDD camcorder, I've edited the post. thanks for pointing it out.
  4. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +620
    7 hours and 20 mins in HQ mode (highest quality setting) on a SR32/SR52.
  5. senu
    senu
    Aug 26, 2005
    19,349
    Denham, South Bucks
    +2,811
    Just remember to get a long life battery .. the supplied ones run out sometimes with even less than 1 hrs shooting
    The best quality is usually about the same as for a DVD which uses mpeg2 and uses up 4.7Gb for 1hr at best quality
    So 6-7 hrs is a Good estimate although Mark seems to have exact figures above
  6. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +620
    I agree, taking the amount of GB (e.g. 30) and dividing by 4.7 will give you a rough idea.
    7 Hr 20 min is the exact amount for the SR32 from the manual. It's a bit more than the rule of thumb above as it doesn't quite use the maximum possible bitrate.
  7. speagle
    speagle
    Thanks for the help. Gives me some more information to help decide!
    Cheers,
    Ian.
