roman700
Established Member
Hiya
I know that if you record on Mini-DV tape with a HD camcorder, you can then transfer the footage to your computer. There you can edit assuming you have one of the latest editing packages (the latest Pinnacle is one).
From there, if you want to retain as much image quality as possible, you have to transfer your edited film back onto the tape, don't you? If you burn a DVD, quality will be lost, won't it?
Are there any computers with a HD DVD burning facility?
How about if you record HD footage with a hard disk/DVD/memory card HD camcorder? Are there any extra issues there?
Thanks.
Chris
Thanks.
Chris
