HD Camcorder & MAC compatibly
g0lgj
Hi I currently have a TRV11 mini dv camcorder and I am thinking of moving to a HD camcorder. I use a iMAC (power PC not intel) and Imovie 07 not imovie 08 , just for holidays and kids so nothing pro. Questions are
Is something like the Sony HC9E compatible withe Imovie 07 and the MAC ?
Once recorded and edited and outputted to DVD if using upscaling DVD player what Quality can I expect ? or would it better to edit back to tape and use camcorder to play on ? using a HD TV.
I have read that there is less compression when using HD-mini dvd tape than some of the other HDD based recorders ? so better to go with tape ?
Any help gratefully received.
Mark
macdaddy
As long as the camcorder you are thinking of buying doesn't record AVCHD files you'll be OK.
iMovie 07 won't work with AVCHD.
MD
g0lgj
Hi Thanks for your reply so I presume most HDD based camcorders record AVCHD files if I stick with mini DV HD tape should be ok.
Thanks.
milkmanchris
Get a copy of iMovie06 its a lot better than 07.
Voltaic will convert any avchd files into files readable by iM.
D
Deleted member 27989
For the record iMovie 07 does not exist, there was iMovie 06 HD and iMovie 08. Whilst 08 might not be to everyone's taste it actually has a lot more features that 06 and were very quietly introduce following the launch, so anyone discarding it then I would suggest to give it another good look...
But yes if you are on a non-Intel Mac do not go for AVCHD based cameras...
macdaddy
Agreed - just another process to have to go through though......
milkmanchris
For us G4 non Intel chip dudes, it would seem the only way.
