HD Box Recorded program problems
Discussion in 'Satellite TV, Sky TV & FreeSat' started by ittim, Apr 26, 2007.
  1. ittim
    ittim
    Nov 30, 2006
    356
    +7
    Less than 24hrs after install and i've had my first problem.
    I recorded a program last night and when i go to watch it i can't get any further than the 'start program screen' the one where it gives you the synopsis of the program and a position from which to start it.
    All other recorded programs work fine but this one particular one will not play. I've tried pressing the play button, the select button, and i've tried setting a time in the middle of the program all to no avail!
    I hope i haven't gone and bought a duff box!!!
    Has anyone else experienced similar?
  2. NEIL J JONES
    NEIL J JONES
    Did you install it or did a Sky engineer.
    When mine was installed the engineer checked single and duel recordings and playback to make sure they worked properly before leaving.
  3. JimmyT
    JimmyT
    Apr 8, 2005
    216
    +9
    I think i have had that twice since i got my box when they first came out. I could not get it to play so just deleted the recording. It didnt affect the box itself.
  4. Sonic68
    Sonic68
    Feb 6, 2006
    63
    +3
    Wasn't battlestar was it? This has happened to me this week as well. First time it's done it though and my box is nearly a year old.
  5. ittim
    ittim
    Nov 30, 2006
    356
    +7
    No it was grand designs... program before it recorded okay as did programs after it. I'm worried i've bought a lemon.
  6. sizedoesmatter
    sizedoesmatter
    Dec 5, 2006
    375
    +27
    Yep that happened to me as well.
    However this is now the 7th or 8th time it has happened.
    Get used to it I am afraid, probably related to Anytime so I am considering switching it off.
  7. ittim
    ittim
    Nov 30, 2006
    356
    +7
    what makes you say its realted to anytime?
  8. JimmyT
    JimmyT
    Apr 8, 2005
    216
    +9
    It happened to me last year so i doubt its anytime related.
  9. ittim
    ittim
    Nov 30, 2006
    356
    +7
    If its likely to be a regular occurance i'm not so sure i want it....:confused:
  10. Caveman643
    Caveman643
    Jun 16, 2005
    516
    Harrogate, UK
    +51
    I had this with Battlestar as well this week. the 1st failed recording I've had. Luckily Battlestar is repeated in the early hours of Mondays. 1am I think.
  11. ittim
    ittim
    Nov 30, 2006
    356
    +7
    Thing is that this isn't a failed recording.
    its there, used 2 % says recorded, end time of 61 minutes. Its all there. i just cant get it to play.
  12. nictry
    nictry
    Apr 28, 2002
    5,846
    Kent
    +652
    Were you watching another channel and recording 2 programs on the same channel one after another? If so this is apparantley a known fault that a lot of people suffer from, prime example is Lost and 24 on Sunday nights, I have lost the 24 episode exactly as you describe because I was watching another channel while it was recording :suicide:
  13. Smurkenstein
    Smurkenstein
    Sep 23, 2006
    525
    28
    +28
    Happens to me. box gets very hot.
  14. ittim
    ittim
    Nov 30, 2006
    356
    +7
    Yes, i was watching Liverpool v Chelsea, on Ch4 i recorded Property ladder and Grand Designs after it.
    I wonder if it could be something to do with the setting that starts / ends recodings over lapping? :confused:
  15. mugsy
    mugsy
    Nov 1, 2002
    687
    Kent
    +20
    I was watching/recording exactly the same programs and my Grand Designs recording is the same as yours - it all looks OK in the planner but when you try to play it nothing happens.
    I wonder if Sky are aware of this issue :confused:
  16. ittim
    ittim
    Nov 30, 2006
    356
    +7
    Wow, glad i'm not alone (phew!)
    Maybe i'll drop them an email
  17. sizedoesmatter
    sizedoesmatter
    Dec 5, 2006
    375
    +27
    I reported mine yesterday and said I wasn't the only one as this site had other people posting about it.
    Anyway an engineer is coming out tomorrow to take a look so watching everything as fast as possible & archiving overnight in case they take the box.
    I also asked about the system health check system. Apparently hasn't been released to HD boxes yet, only Sky+ boxes.
  18. ittim
    ittim
    Nov 30, 2006
    356
    +7
    I'd be really interested to know what they do, can you keep us informed. My box is only 3 days old. I may have to check the model and firmware revision but i was led to believe it was the latest one. if thats the case then a new box is unlikely to fix your problem.
    interesting that they're sending out an engineer for a problem which is probably a known fault
  19. 3rdDegree
    3rdDegree
    Dec 13, 2005
    266
    Dublin
    +12
    I've had this problem a number of times with a Sky+ box (NOT HD). The program will sometimes freeze during playback. Sometimes, setting the viewing time to a minute or so after the freeze will solve the problem. It is very possible that it is related to recording one program after another with overlap between them (something I often do) while watching another program.
  20. ittim
    ittim
    Nov 30, 2006
    356
    +7
    I dont think thats quite the same problem. with mine it will not play. You can't get it past the screen where you would press play.
  21. sizedoesmatter
    sizedoesmatter
    Dec 5, 2006
    375
    +27
    Engineer came, mildly interested in what the problem was, just said "you might as well have a new box", which I wasn't going to argue with, he said it was "brand new" (and came straight out of the new box I could see the manual, warrantly card etc), apparently hardly any recon boxes out there at the moment apparently as still so new.
    Now if its a brand new one, will my warrantly period start all over again?
    No anytime now though, not that I care particularly, despite two forced software updates & old epg with HD channels on the red button.
  22. mugsy
    mugsy
    Nov 1, 2002
    687
    Kent
    +20
    I don't think a new box will cure this to be honest as mine is only a couple of weeks old and Ittim's a week or so. More likely a software issue but as to whether they will acknowledge/fix it... :(
  23. ittim
    ittim
    Nov 30, 2006
    356
    +7
    At least you got a new box out of it!
  24. OxfordPaul
    OxfordPaul
    I've been having similar problems since I received my HD box three weeks ago. Recorded programmes not playing back, programmes scheduled to record either showing 'Failed' (powercut) or just being deleted from the planner prior to the record time. Now on my second HD box. The first one had the Anytime option, the second hasn't (yet), different EPG software versions yet still the same problems. Really frustrating and we've missed episodes of Desparate Housewives, Lost, 24 and Battlestar as a result.
    I spoke to Sky's contact centre this evening and they now admit this is a known issues with HD. I said I wanted to switch back to SD Sky+ as I still have the box. I was assured their techies are working on a HD software fix, and they've promised to call me back tomorrow with timescales for this to happen. If this isn't imminent then I'll ask them to take the HD box away, give me a full refund and reinstall my old Sky+ box. A bit of compensation for the missed shows, phone calls and time wasted wouldn't go amiss either.
  25. mugsy
    mugsy
    Nov 1, 2002
    687
    Kent
    +20
    Mine did it again tonight - was watching the Milan/Man U game and recording property ladder and grand designs. Property ladder is fine but although grand designs seemed to record OK and is in the planner OK nothing happens when you try to play it :(
  26. theadviser
    theadviser
    Jan 4, 2003
    +4
    Happened again with me tonight. Watching football and recording Property Ladder then Grand Designs. Anyone know if Grand Designs is repeated :lease: :lease:
    Mugsy beat me to it!!
  27. ittim
    ittim
    Nov 30, 2006
    356
    +7
    I havent checked my grand designs yet, will do tonight. i believe its repeated on More4 sometime tonight!
  28. ittim
    ittim
    Nov 30, 2006
    356
    +7
    Okay, Seriously considering ditching this HD Box. It did the same bloody thing again on Friday night. I recorded Derryn Brown, Peep Show and Pheonix nights guess what... thats right. I can't play the Peep Show episode.
    As before, i click play but nothing will get the program on.
    I've now played around with some of the sky plus settings but i doubt this will work.
    who should i complain too? sky or midsat?
    My 4 Year old Amdrad Sky plus box could cope with recording 3 programs together so why the hell can't this so called 'future of tv'?!?
    I can forgive its other annoying quirks but this one just defeats the point!
  29. Algoz
    Algoz
    Nov 12, 2005
    541
    Woking Surrey
    +14
    I had the same with "Human Footprint". Settled down to watch, pressed play and then NARDA. Only solution was to delete the recording.
    First time it's happened to me though......
  30. jont
    jont
    Apr 8, 2002
    4,335
    near Aylesbury
    +577
    Not one to ever stand up for sky ... but the box is doing *a lot* more processing with one, two or 3 HD programs on the go at once !!
    I posted about this a few weeks ago when I was chasing playback of Superstorm on BBC1HD and recording 24 & Lost back to back on SkyOneHD ... at the programme change the box crashed and I lost the rest of Superstorm and 24 ...
    This has happened a few times now ... thankfully Superstorm has now finished so no Sunday night probs !!
    I hope that a software fix will sort out otherwise I think sky will have to accept a lot of HD boxes being returned as not fit for purpose !!
    Jon
