HD Box Question.
Discussion in 'Satellite TV, Sky TV & FreeSat' started by indianwells, Aug 4, 2006.
  1. indianwells
    indianwells
    Jul 14, 2006
    2,094
    116
    Anna Kournikova's Bicycle Seat.
    +1,166
    Ever since it was installed,when I switch my Pio Plasma off you can still hear the programme that's on so I have to turn the HD box off aswell.I suspect it's something simple.Can anyone help?.Thanks in advance.:)
  2. Cupart
    Cupart
    Feb 14, 2006
    517
    28
    Dublin 2 / Paris 75001
    +23
    How is the SKY HD box connected to the plasma screen?
  3. brendan_dj
    brendan_dj
    Feb 1, 2005
    1,293
    New Jersey, USA
    +99
    Do you have and audio cable going directly from the Sky digibox to an Audio amplifier?
    You need to power the audio amplifier off separately. as turning the TV off will have no effect on any other external audio amplifier.
  4. indianwells
    indianwells
    Jul 14, 2006
    2,094
    116
    +1,166
    Component.
  5. Tuscan
    Tuscan
    Jun 20, 2006
    443
    Manchester
    +20
    Component is picture only.
    So i take it you must be using an external amp for audio using the digital audio connection.
    Turning the TV off by itself will have no effect on audio, the amp has to be turned off separatley to turn the audio off.
