HD aerials
Discussion in 'Freeview & YouView' started by mr.nbuk, Feb 12, 2009.
  1. mr.nbuk
    mr.nbuk
    Mar 13, 2008
    3
    what is the difference between a digital ready aerial and a hd compatible aerial?
  2. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,731
    Somewhere in South Yorkshire
    +6,306
    Both are (arguably) ficticious terms/claims. A UHF TV broadcast is "the same" regardless of what they convey - digital, analogue, whatever. The only thing a "digital aerial" needs to do specially, is be optimised for the frequency range used at your transmitter - and these may differ from the range used for analogue, depending on the transmitter.
  3. scribbler101
    scribbler101
    Jun 17, 2008
    1,407
    63
    +113
    Bovine excrement.
    All radio signals are analogue; even if they are carrying a digital signal. The only time a different aerial is needed is if different ranges of transmission frequencies are needed.
  4. fernandez
    fernandez
    Jun 5, 2005
    6,039
    +995
    As above and there aren't even any HD terrestrial transmissions yet:eek:
  5. mr.nbuk
    mr.nbuk
    Mar 13, 2008
    3
    Thanks, but I already understood the frequency issue regarding different transmitters.
    It is the fact that I have looked at various Digital aerials and in particular the Triax 343 is advertised as being HD Compatible. I wasn't sure if this particular aerial did something other Digital aerials do not.
  6. GaryB
    GaryB
    Nov 12, 2002
    5,393
    St Albans
    +1,303
    Apart from including a bit of Marketing BS on the box, it's the same as any other aerial.
  7. scribbler101
    scribbler101
    Jun 17, 2008
    1,407
    63
    +113
    The pedants here would insist that you have looked at various aerials, not various DIGITAL aerials, because (all together now) "There's no such thing as a digital aerial"
    It would be interesting to ask Triad to describe the special digital design features.
    http://www.triax.co.uk/?alPage=&rkPage=&articleId={D2CB728D-1845-4E5F-87B3-86DD11379505}
    It is, of course, "HD Compatible". But so is any 20 year od UHF Aerial.
  8. mike7
    mike7
    Jan 3, 2005
    4,949
    Norfolk
    +618
    It is, of course, "HD Compatible". But so is any 20 year old UHF Aerial.
    Or, indeed, so is a length of wet string if you live next door to the transmitter.:)
  9. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,280
    Manchester
    +763
    Don't forget that for HD digital television you must use HD compatible coaxial cable for your aerial downleads too; otherwise you'll negate the efficacious effect of your use of that special antenna in the first place :D
    (snake oil must be used with more snake oil)
    Chris Muriel, Manchester
  10. fernandez
    fernandez
    Jun 5, 2005
    6,039
    +995
    For some reason the Tiriax link isn't 'live' so try this
    Triax - United Kingdom
    Their explanation should be interesting
  11. radioredcat
    radioredcat
    Jul 4, 2008
    620
    28
    st helens
    +71
    I don't need a HD aerial as iv'e not got a HD telly yet.
    I think you chaps have summed things up nicely the only thing iv'e got to say i own a triax aerial i wonder if that will be good for HD.
    ANDY
  12. scribbler101
    scribbler101
    Jun 17, 2008
    1,407
    63
    +113
    Naughty Andy. Some may not see your tongue there in your cheek.
    I phoned Triax technical dept. and asked in what way their "Digi 343" was "Specially designed for digital reception". Didn't get a very coherent answer! But they did mention that it had a balun on the dipole.
  13. mike7
    mike7
    Jan 3, 2005
    4,949
    Norfolk
    +618
    I think you can get some ointment for that ! :thumbsup:
  14. radioredcat
    radioredcat
    Jul 4, 2008
    620
    28
    st helens
    +71
    Nice one about the balun.HA HA
    I wonder if they know that baluns have been used since the year dot.
    andy
  15. scribbler101
    scribbler101
    Jun 17, 2008
    1,407
    63
    +113
    They knew that - but apparently their cheap "Contract" aerials are unbalunced.
  16. mike7
    mike7
    Jan 3, 2005
    4,949
    Norfolk
    +618
    I saw One for All brand amplified set-top aerials in Maplins that have marked on the box that they pick up HD TV. How confusing is that?
  17. radioredcat
    radioredcat
    Jul 4, 2008
    620
    28
    st helens
    +71
    Thankfully not confusing for us on here or anyone you has read this thread,It's the non technical people you are going to get conned!
    Yesterday i was asked this very question by a neighbour so i set them straight and also i told them to pass the info to other people they know.
    andy
