HD-15 cable
Discussion in 'Cables & Switches' started by Ken, Jan 8, 2004.
  1. Ken
    Ken
    Dec 15, 2000
    362
    Stoke-on-Trent
    which hd-15 vga to vga cable would you recommend for a 6m run?
    Ken
  2. Ken
    Ken
    Dec 15, 2000
    362
    Stoke-on-Trent
    No one use vga cables?
    ken
  3. BBD
    BBD
    Mar 13, 2001
    430
    Lutterworth
    +3
    Have a look at Bluejeanscables.com. They supply vga cables constructed using the cables recommended in the sticky on video leads. Cheap fast and excellent quality.
  4. Ken
    Ken
    Dec 15, 2000
    362
    Stoke-on-Trent
    Thanks, but they only do vga to component.
    Ken
  5. tedy
    tedy
    They do VGA to VGA cable at bluejeans.com. You did not read carefully. However for long runs they sugest the VGA breakout cable plus separate runs of coaxial.
  6. tedy
    tedy
    I meant bluejeanscable.com
  7. Ken
    Ken
    Dec 15, 2000
    362
    Stoke-on-Trent
    I don't know what you are reading, but there is no mention of, nor pricing of vga - vga cables. Else I am completely blind.
    Ken
  8. tedy
    tedy
    Go to blujeanscable.com. Press projector/RGBVH.Then underneath Projector,HDTV and RGB you will see HD-15 to HD-15 cables.Press that and what do we see?
  9. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,041
    The Borders
    +2,518
    Ken
    Lots of options for high quality VGA cables around - we supply VanDamme, Supra and BetterCables and there are other options available.
    Any of the three we supply will be no problem over 6m.
    Best regards
    Joe
  10. Ken
    Ken
    Dec 15, 2000
    362
    Stoke-on-Trent
    Thanks. I am blind.
    Ken
