HCPC with Sky
Discussion in 'Desktop & Laptop Computers Forum' started by mholgate, Sep 4, 2003.
  1. mholgate
    mholgate
    Jun 9, 2003
    38
    Hello all!
    I'm planning on using a HCPC box as my entertainment hub.
    Anyone out there who has Sky or Sky+ connected via their PC hub? Is it possible to control the Sky channel you want to record/watch automatically via the computer's TVtuner card for PVR or PC's remote control? (e.g. Hauppauge PVR 250)
    Thanks in advance,
    Mark.
  2. jsmurray
    jsmurray
    Not seen an answer to this yet.
    My tivo has a little ir sender which you hook over the digibox so the tivo can send the signals to change the digibox channel.
    I'm guessing something similar would not be hard to do, but I've not seen anything yet.
    Anyone?
  3. sennen
    sennen
    I don't have one myself -- but take a look at www.redrat.co.uk, it's an IR sender/receiver that could be programmed to control other boxes.
