HCPC (which psu silent/cheap)
Discussion in 'Computer Components' started by vulkan75, Apr 6, 2003.
  1. vulkan75
    vulkan75
    Hey lads how-be?.
    well almost finished building my hcpc components as follows:-
    asus A7V8X motherboard
    athlon2100 thouroughbred cpu
    Thermalright SLK-800 heatsink
    Seagate Barracuda V 60GB 7200RPM ATA100 hd
    PIONEER 106 DVD DRIVE
    radeon 9000 pro gc
    Packard bell tv100 pci
    One last thing the psu.
    what you guys using,recs PLEASE!
    Must be quiet/good price.
    Much obliged
  2. Thrash
    Thrash
    Oct 18, 2002
    201
    16
    Adelaide
  3. MuFu
    MuFu
    Jul 24, 2002
    1,192
    41
    NW2, London
    +4
  4. Punce
    Punce
    Feb 5, 2002
    405
    The Shire, Wales
    +16
  5. loonatic
    loonatic
    Jan 4, 2003
    1,880
    41
    Springwell Village, Gateshead
    +16
  6. james.miller
    james.miller
    Dec 16, 2002
    2,616
    +143
    even a generic psu will be more than adiquate. i took the 350w psu that came with my cheap case, and just 7volt-modded then fans. silent and worked perfectly
  7. Rob.Screene
    Rob.Screene
    Sep 29, 2001
    1,276
    Berks, England
    +131
    Any flames out the back yet? :)
    Rob.
  8. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,493
    Birmingham
    +205
    Have to say I did similar. Replaced the 80mm fan in my cheap Jeantech psu with a Zalman quiet fan and ran it from a 3 pin connector on the motherboard. Near silence with no excess heat generated or reliabilty/stability problems thus far. £22 for the psu, £15 for the fan. Buying saves the hassle of modding, but as I love to play, I was in my element :)
  9. vulkan75
    vulkan75
    Anybody got a psu with fan speed control?
    what is it like on slow temp wise?
    How much did you pay?:rolleyes:
  10. rhinoman
    rhinoman
    Oct 31, 2000
    2,581
    71
    Herne Bay, Kent
    +33
    My Seisonic SS300 has a single thermally controlled fan which is extremely quiet, it runs at the slow speed most of the time only increasing when room tempratures get very high. It costs about £50 which is highish but much quieter than the Enermax with speed control that I had before.
  11. IanM
    IanM
    Dec 17, 2002
    158
    +5
    I went for a Nexus NX3000 because it was recommended on www.silentpcreview.com
    It was £60 but much quieter than the supoosedly silent Q Technology and Power Man models that I'd tried before.
  12. feet14
    feet14
    Mar 13, 2002
    88
    UK, West Midlands
    If you're capable enough, buy a reasonable PSU and swap the fan for a Papst one. Also, place the fan out of the back of the PSU casing and attach it using elastic bands etc to reduce vibration as I found even with a 7-volted Papst inside my PSU the noise was too noticeable.
