hcpc videocard options
whistlingDogg
I'm planningon getting a pioneer 433mxe plasma screen and was considering using a hcpc for dvds as this should give me the best picture quality.
Can anyone recommend a good video card, dvd player and sound card that I could use.
I don't think I require any tv tuning as I don't have an aeiral. I have a us xbox and plan to connect this via components. the only other connection would be the sky digital box. Could I input the sky signal to the video card for best picture? Do video cards have svideo inputs?
Any comments would be welcome
ChrisAllenFiz
Does your plasma have a VGA input? If so then this would be the best way to connect your pc to the plasma. I would recommend a Radeon 9000 series for picture quality on dvds. Sound card is a difficult one as it depends if you are going to have an external amp to do the processing or if you intend to do it on the sound card.
I think you will need a Tv capture card if you want to input to the computer, and then you can output to the plasma after the signal has been cleaned up.
HTH
Chris
whistlingDogg
the plasma does indeed have a vga input. it also has a dvi input. All I want from a sound card is the ability to output a digital coax or optical signal to my denon 3802
Respectamonkeee
I'd go for the cheaper GF TI 4200 from leadtek...for £120 it allso offers vivo and a lot more graphic power then the ati 9000 series
tho the 9700 is a monster card
the leadtek you can make passive as well so a silent htpc is on the cards;)
J
Jenz
Originally posted by Respectamonkeee
I'd go for the cheaper GF TI 4200 from leadtek...for £120 it allso offers vivo and a lot more graphic power then the ati 9000 series tho the 9700 is a monster card
Except that this is a Geforce card and gives a lower picture quality.
E
EvilMudge
If you can still find one, an All In Wonder 8500DV is probably the best hcpc graphics card you could ask for - I'm seriously impressed with the video de-interlacing and scaling performance from my AIW Radeon - it makes VHS watchable again!
Dog Soldiers & Flatliners 4K, Black Phone, RRR & Mad God on digital, plus 4K + Movie/TV News
