HCPC Upgrade
Molly
I currently have a HCPC with the following spec:
Abit NF7-S
AMD XP 2000
512MB ram
Radeon 9600
I have just purchased a Pioneer MXE and High def films are now high on the agenda. I use Theatertek with no FFDshow. Some films are ok with no skips or jumps etc, others jump every 5 seconds. My main problem seems to be 1080i films.
If I upgrade to the following:
AMD XP3200
Nividia 6600GT
will this solve my problems?
owain_thomas
it should do, you may want to get some more memory too (1GB).
Rambles
Should be good, there is a microsoft patch to get the video card gpu do some of the hardware accelaration for wmv hdef files.
owain_thomas
hi lisa, does that patch work with TT or is it just for WMP? do you have link for it?
thanks
owain
Rambles
owain_thomas said:
hi does that patch work with TT or is it just for WMP? do you have link for it?
thanks
owain
Not sure about TT - here is the link...
Similar threads
