HCPC to HS10/20 in GBR mode @50Hz =shimmering
Discussion in 'Projectors, Screens & Video Processors' started by Comer, Sep 26, 2004.
  1. Comer
    Comer
    Sep 21, 2001
    1,386
    Ireland
    +86
    I have had enough of the juddery pans using the HS10 at 56Hz refresh rate so I am now using the following powerstrip timings:
    1184x666=1184,160,56,256,666,30,6,46,61934,1 with projector computer signal set to GBR
    This gives me most of the advantages of using a PC with (IMO) very little loss in picture quality watching DVDs and perfectly smooth pans for PAL material. But it seems to me that the nature of Home Cinema is that when you solve one problem, you create another. And this situation is no exception. I now have shimmering on the desktop that is sometimes evident when watching a movie. I have to stop the movie and keep changing the screen resolution away from 1184X666 and back again until it goes away. I can be lucky and have a rock solid picture for a full nights viewing or (more often) the shimmering can plague me all night.
    Has anyone else experienced this? what causes it and is there anything I can do about it
    Thanks in advance
    Conor
  2. kotlewm
    kotlewm
    Jul 1, 2001
    216
    Fife, Scotland
    +8
    I'm running the same timings via a Radeon 9600 DVI into my HS10 and don't experience the same problem. The only issue I have with this resolution is 5 pixel line of "blockiness" down the right hand side. I remove this by using the masking on theatertek.
    Have you tried the 720p resolution? It means lots of overscan, but may be interesting to see if it resolves the "shimmer"
    1280x768=1280,64,56,280,768,1,3,23,66780,2304
  3. Comer
    Comer
    Sep 21, 2001
    1,386
    Ireland
    +86
    Thanks for the reply
    I have tried the above timings before and they do eliminate this shimmering but the overscan is unacceptable to me. I can go into powerstrip and change the refresh rate and it removes the shimmering but when I restart the PC the shimmering is back so I need to do this again. Timings that do not cause shimmering will after a reboot. I suppose that I can live with having to do this in powerstrip every time I start the PC if it is necessary
    Conor
