Quantcast
hcpc - crestron intragration
A
AVMADMAN
Anyone any suggestions how this could be done?
Would the use of irman be the best option?
Thanks:D
pemberto
AVMadman,
From what to what are you trying to connect up. What Crestron processor are you using? And what operating system do you have on your HCPC.
A
AVMADMAN
st1550c + st-cp control processor and XP pro
I would like to be able to control all dvd functions and maybe que ups if possible for the pj.
Thanks for any advice pemberto
pemberto
Adam,
I could not find what I was looking for in terms of a direct connection between Windows XP and Crestron, but I will have another look. I did how ever fidn this, http://www.automatedaudio.com
Might be worth a look as it does not appear to cost that much.
If I find anything else I will let you know.
Paul
A
AVMADMAN
Thanks pemberto
Thats looks as though it might be the ticket:D
pemberto
Adam,
Managed to get some more info, thanks to some of the guys on a Crestron forum I belong to. Here are the responses to the same question you asked.
1. One that I've seen mentioned on The Green Button
(http://www.thegreenbutton.com/) is called MCE Controller. More info is at http://www.kindel.com/. As far as I know, it's one-way control only at the moment - more reliable than simple IR control, but no feedback data, so if you're looking at putting status/song/artist info on a touchpanel you're out of luck.
2. I have the HP Windows XP Media Center on my system
and it is all IR controlled as far the Media Center is concerned.
3. Also checkout: www.streamzap.com - USB IR Receiver plugs into compurter and remote gives you transport controls, number buttons, menu controls, channel & volume, mute & power and 4 programmable buttons to start any programs you like.
Let me know which one you go for and how you get on. I'm just about to get my crestron system up and running and may go down the MS Media Centre myself.
Paul
Similar threads
