HCPC & AE100 setup queries - resolution not right?
Discussion in 'Desktop & Laptop Computers Forum' started by RichardH, Aug 7, 2002.
  1. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    Hi all, I've have a poke around and can't see the answer to my query, so here goes.
    I've just got my HCPC going - Radeon VE with 6093 drivers, Powerstrip etc. Following this thread over at AVS, I've configured Powerstrip and messed with the dot clock and clock phase.
    However, I'm surprised that text on the Windows desktop is manky - see this screenshot for what I mean - it looks like it's not at it's native resolution....
    I have it set at 856 x 480, and have also tried 858 x 484 as listed in the manual's spec as the panel resolution, but not much different, really. I know it's not quite the same once a film's running, but should I be getting better?
    Thanks in advance, all
  2. JSW
    JSW
    Feb 21, 2002
    4,283
    Staffs
    +333
    Text should be ok take a look at screenshots in my album
    they are 856 x 480
    pics 21 - 24
  3. MartinCo
    MartinCo
    Apr 4, 2001
    853
    Liverpool
    text should definitely be okay.
    try 1280 x 720 if you want a bit more desktop space...(WIDE720).
    there are details on it at avsforum.
  4. JSW
    JSW
    Feb 21, 2002
    4,283
    Staffs
    +333
    Have you got a link to it ???
  5. calibos
    calibos
    Aug 4, 2000
    931
    Ireland
    +33
    PowerStrip timing parameters:
    Copy line below to clipboard(ie. copy) and then in custom timings within powerstrip click the copy from clipboard button(ie. paste)
    1280x720=1280,56,120,240,720,4,6,20,76500,7
  6. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    One thing - should I get "WIDE 480" pop up as the projector detects the signal? Currently I'm just getting it say PC Auto.
  7. JSW
    JSW
    Feb 21, 2002
    4,283
    Staffs
    +333
    enter the menu and it will show wide480
    calibos, Thanks :)
  8. johnm60
    johnm60
    Feb 2, 2002
    109
    Shropshire, UK
    +7
    have you got PC priority set to "Wide" in the options menu? The projector definately should be showing wide480.
  9. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    johnm60, you're a genius. That's a lot better!!!!!
    R
  10. MrCoopz
    MrCoopz
    Jun 28, 2002
    1,075
    63
    +102
    I have the same problem as Richard and have been messing about for most of the day trying to get wide480 to show up!
    what do u have to do to get it, do u need software. is there a certain way of connecting my PC to the PJ??
    Help me plz
  11. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    Go in to the OPTION menu, and set the PC PRIORITY to WIDE.
    Now go to the link in my initial post for how to set up Powerstrip and the Dot Clock and Clock Phase.
  12. MrCoopz
    MrCoopz
    Jun 28, 2002
    1,075
    63
    +102
    the link dont work mate would it be possable to post them on here??
  13. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    AVS forum is down for maintenance, so that's why it's not there.
    You need to install Powerstrip - get it from here
    Install it, then right click on the system tray icon, choose Display Profiles|Configure. Click the Advanced Timing Options button, then the Custom Resolutions, then copy the following to your clipboard (without the start and end lines):
    ======start=======
    856x480=856,56,88,64,480,1,3,12,31665,7
    Generic timing details for 856x480:
    HFP=56 HSW=88 HBP=64 kHz=30 VFP=1 VSW=3 VBP=12 Hz=60
    Linux modeline parameters:
    "856x480" 31.665 856 912 1000 1064 480 481 484 496 -hsync -vsync
    ======end=======
    These are my settings, which should do you OK. Can't do a screen shot at the mo 'cos I don't have any imaging software on that PC.
    You should see an icon near the bottom right of the screen that looks like a clipboard - click it, and you should get the settings filled in.
    Save it, and you'll be asked to do various bits which should be self explanatory.
    That will get you the 856x480 resolution. See previous for setting the Panny up.
    To adjust Dot Clock and Clock Phase, you need to set the image found here http://www.marky.com/files/hometheater/testpatterns/tracking-and-phase.gif as your TILED background. Then mess with the Dot Clock until you see no vertical bands, and if need be adjust the Clock Phase. See http://www.marky.com for more info.
    After typing all of that, it looks like the AVS forums are back up - so between this and that you should be fine.
    R
  14. MrCoopz
    MrCoopz
    Jun 28, 2002
    1,075
    63
    +102
    thanks Richard it now looks Amazing i cant believe how it looked before.
    but a few more questions is there anyway to set it so i can switch resolutions without going to display properties?
    and how can i use these setting for games?
    and my desktop is massive how can i make things smaller?
  15. MrCoopz
    MrCoopz
    Jun 28, 2002
    1,075
    63
    +102
    Help i wanna make my games look better
