HCC Infocus 5700 review?
Discussion in 'Projectors, Screens & Video Processors' started by keyser, Dec 18, 2003.
  1. keyser
    keyser
    Jul 23, 2000
    903
    gardabaer, Iceland
    The magazine hasn´t arrived yet here in Iceland.. what did they say in their review?
  2. WSquared
    WSquared
    Jan 31, 2001
    215
    Bristol, UK
    +3
    I don't have my stack of HCC mags to hand, but you can have a look at a calibration report that I produced for the Infocus Screenplay 5700 over on my website.
    I have included a number of thoughts on the 5700 in the cal report.
    For a unit that is supposed to be factory calibrated to D6500, the ISF calibration made a significant difference.
    Regards, William
  3. venkman
    venkman
    Jan 17, 2003
    82
    Keighley
    +4
    It gets a 5 star review - "Picture quality is simply first class".
    Only small criticisms are lack of lens shift, blacks could be better and lens barrel silver / grey colour affects contrast.
    They also mention how sky+ owners will like the s-video inputs; surely they would be better off with the RGB scart input!? The remote is also criticised for not being backlit, but it is!!
  4. tekmonkey
    tekmonkey
    For what it's worth, having experienced the Infocus Screenplay 5700 played with it and set it up I wouldn't even dream of spending £3000 on it, £3750 will buy a Sim2 Domino 20 which is ten times as good.
    I'm not saying that it is especially bad, but it is not a 5 star machine its a 3.5 star machine at best, in comparison to the competition.
    The monkeys are coming!!!!!
  5. GaryG
    GaryG
    Nov 20, 2002
    746
    Shropshire
    I didn't think it was much of an advance on the old NEC LT150, the blacks weren't much so much better that you'd notice and although the rainbows weren't quite as bad they were annoying and I got a headache within a couple of minutes of the demo.
  6. venkman
    venkman
    Jan 17, 2003
    82
    Keighley
    +4
    Well, for what it's worth, I wouldn't dream of spending nearly £4000 on a projector without a digital input. For use with a HCPC / future proofing, I would say this gives the 5700 the edge, especially with HDMI just arriving.
    For an extra £1000 I would hope the Domino is better, but I think we are talking about very small improvements here.
  7. keyser
    keyser
    Jul 23, 2000
    903
    gardabaer, Iceland
    Is it possible to say that the Domino is better. Don´t both machines have pro´s and con´s. The 5700 is MUCH brigther isn´t it, so for those that don´t have good light control the 5700 should be "better", but for those that have dark rooms then the Domino might be better. And for those that have DVI dvd players, the 5700 might be better.
  8. tekmonkey
    tekmonkey
    Digi input is a fair point but at the end of the day component is still the best in terms of compatability.
    But thats not what I'm saying take 1 DVD player for instance Denon 2900 v.popular what is it going to look better on assuming its reasonably dark(not black out!) Sim2 ! At this level I don't think £750 is a lot extra to pay for that better picture.
    IMHO - I don't think brightness is all that important anyway, contrast ratio far more important, the problems is contrast ratio can v.easy be exaggerated.
    Any thoughts?
